follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 9
1
2
3
4
5
Last
Showing results 1 to 30 of 249
Search took
0.02
seconds.
Search:
Posts Made By:
ILLSMOQ
Forum:
Engine Swaps
11-24-2022, 07:01 PM
172
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP
77,953
Posted By
ILLSMOQ
Sorry, I don’t get back here often lol. The car...
Sorry, I don’t get back here often lol. The car is awesome, been having a blast with it.
I usually stick to Instagram these days. @ls3brz
Since 2018 I’ve done a lot with it. Dry sump 434...
Forum:
Engine Swaps
05-01-2021, 09:12 AM
99
DIY LS3 swap kit - long term testing & improvements
37,166
Posted By
ILLSMOQ
You will want to insulate your exhaust as best...
You will want to insulate your exhaust as best you can particularly near the area where the aluminum flanges are joined to the carbon.
I also had a Carbon Shaft from DSS. Beautiful piece, but the...
Forum:
Engine Swaps
04-21-2021, 09:58 AM
86
Needed a new project... LS3 soon!
23,647
Posted By
ILLSMOQ
Check your throttle travel/calibration I...
I ran into throttle issues in the beginning as well with my motec build. I discovered as I went to WOT, if I pushed the pedal harder, the floor board (where...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
11-08-2019, 10:20 PM
30
BIG Brembos, MCS coilovers, SPl Suspension 285/30’s and 18x10 ZE40’s
10,903
Posted By
ILLSMOQ
I’ll also tell you that while the 18x10 +40 is...
I’ll also tell you that while the 18x10 +40 is cool 18x9.5 +40 works a little bit better, and still fits the 285 perfectly
Forum:
Engine Swaps
10-23-2019, 10:22 AM
236
Mitsurugi: Reforged
51,794
Posted By
ILLSMOQ
Can you get a base map from someone that you know...
Can you get a base map from someone that you know for sure works? At least to get you close.
Forum:
Engine Swaps
08-15-2019, 01:42 PM
5
Fuel system ideas?
2,004
Posted By
ILLSMOQ
I bought the radium filter and mount. ...
I bought the radium filter and mount. Massaged(pounded) the floorboard in under the driver seat to get it up above the lower points of the floor board. Then I made an cover/skid plate for it all...
Forum:
Engine Swaps
06-18-2019, 10:20 AM
1,305
Another V8 Swap
320,533
Posted By
ILLSMOQ
1500 miles lol. The engine builder said those...
1500 miles lol. The engine builder said those cracks were common and superficial on the PRC heads though. :wub:
Forum:
Engine Swaps
03-04-2019, 11:06 AM
36
a gt86 @ 1800whp LSX
12,246
Posted By
ILLSMOQ
Is this a 4.125 bore 427? Square, Rectangle or...
Is this a 4.125 bore 427? Square, Rectangle or Cathedral on the heads? I’m interested to see how your build progresses. After I get the get the track day bug out of my system, I’d like to switch...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
01-16-2019, 05:37 PM
15
guys with meaty tires and big power, 17x8 vs 18x9.5?
5,234
Posted By
ILLSMOQ
Are you just trying to go straight or do you want...
Are you just trying to go straight or do you want it to handle too?
For my street setup I run 285/30/18 re71r’s on two different sets 18x10’s and 18x9.5’s both +40. The grip on the turns is...
Forum:
01-16-2019, 12:36 PM
2,548
Meaty Tire Thread
1,734,802
Posted By
ILLSMOQ
18x9.5 +40 would give you the same look with out...
18x9.5 +40 would give you the same look with out having to do all the extra stuff to tuck the 10’s
Here is how mine looks with 18x9.5 +40 and 285/30/19. They would poke out a touch more without...
Forum:
01-16-2019, 11:38 AM
2,548
Meaty Tire Thread
1,734,802
Posted By
ILLSMOQ
+40:thumbup: Also needed to narrow the track...
+40:thumbup:
Also needed to narrow the track to tuck them under the fenders.
http://www.ft86club.com/forums/showthread.php?t=122384
Forum:
12-27-2018, 07:57 PM
2,548
Meaty Tire Thread
1,734,802
Posted By
ILLSMOQ
Different kind of meat. :burnrubber: 17x9...
17x9 +40 Konig Ultraform - clears 345mm rear brembo GT Brakes
275/40R17 Hoosier DR2
https://i.imgur.com/xgM4lFF.jpg
https://i.imgur.com/yz1oYgt.jpg
Forum:
Northern California
12-11-2018, 12:37 PM
0
$200.00 for some help in San Jose
1,470
Posted By
ILLSMOQ
I need access to a 2017 or newer 86 to pull airbag data from the ecu.
I have an LS Swapped 2017 BRZ running a motec ecu. The Motec unit was setup using earlier 86 firmware and since the ‘17 and...
Forum:
Engine Swaps
12-05-2018, 10:19 AM
172
77,953
Posted By
ILLSMOQ
Thanks! I see 6 mpg when I check the gauge lol. ...
Thanks! I see 6 mpg when I check the gauge lol. But I can’t keep my foot out of it.
Forum:
Engine Swaps
10-23-2018, 01:09 PM
172
77,953
Posted By
ILLSMOQ
Tried drifting...didn’t work out so good. Not as...
Tried drifting...didn’t work out so good. Not as easy as I thought it would be.
https://youtu.be/rq4FO9kYsoo
Forum:
Engine Swaps
10-22-2018, 08:11 PM
173
LS3 BRZ
56,516
Posted By
ILLSMOQ
:thumbup: hahaha!
:thumbup: hahaha!
Forum:
Engine Swaps
10-20-2018, 11:37 PM
173
LS3 BRZ
56,516
Posted By
ILLSMOQ
Lol. Mines kinda big, makes me smile a lot :) ...
https://i.imgur.com/EZqtfTe.jpg
Forum:
Engine Swaps
10-18-2018, 10:39 PM
173
LS3 BRZ
56,516
Posted By
ILLSMOQ
Smart move, sending it to Pure. Should save you...
Smart move, sending it to Pure. Should save you alot off headaches. Buy a new motor if you can swing it to try eliminate unknown issues with a used motor.
I have a Ford 8.8 rear, which can...
Forum:
Engine Swaps
10-17-2018, 12:03 AM
216
2013 FRS | Documented LS2 Swap | How to DIY + Parts List + CANBUS
178,064
Posted By
ILLSMOQ
Whatch the other bolts in the tunnel too, parking...
Whatch the other bolts in the tunnel too, parking brake etc.
Forum:
Engine Swaps
10-16-2018, 10:47 PM
172
77,953
Posted By
ILLSMOQ
Engine was heating up during extended aggressive...
Engine was heating up during extended aggressive backroads driving on 90 degree+ days. Worked on some ducting to get more air through the radiator.
Had the engine cooler mounted to the factory...
Forum:
Engine Swaps
10-15-2018, 02:36 PM
22
So I did a thing! LS7
10,891
Posted By
ILLSMOQ
Let’s see it!
Let’s see it!
Forum:
Engine Swaps
09-25-2018, 06:08 PM
186
Veldin's 2014 Subaru BRZ gets a 2JZ.
87,201
Posted By
ILLSMOQ
Definitely a keeper! Awesome build, even more...
Definitely a keeper! Awesome build, even more awesome when your girl is in it with you!
My wife made our whole little family shirts haha. :thumbup:
https://i.imgur.com/bbpzQ3I.jpg
Forum:
Engine Swaps
09-21-2018, 02:42 PM
9
Post your Radiator/Fan Shroud setups for V8 swaps!
4,248
Posted By
ILLSMOQ
I have the full blown rad and fan shroud kit. ...
I have the full blown rad and fan shroud kit. 900 cfm fans were not up to the job. I upgraded to the 1300 cfm fans and it does great except for extended aggressive back roads driving where after...
Forum:
Engine Swaps
09-19-2018, 12:31 PM
1,305
Another V8 Swap
320,533
Posted By
ILLSMOQ
You know, mine (same motor as Dustin) used to be...
You know, mine (same motor as Dustin) used to be loud and I also was uncomfortable with the noise but it has since quieted down...I used the “drive it like I stole it” method to break it in.
Forum:
Engine Swaps
09-13-2018, 10:18 PM
172
77,953
Posted By
ILLSMOQ
https://youtu.be/8SCv0UukKec I’ll leave this...
I’ll leave this here.
Forum:
Engine Swaps
09-13-2018, 10:01 PM
42
How do I run my heater lines?
11,911
Posted By
ILLSMOQ
https://www.summitracing.com/parts/ear-at165010erl...
https://www.summitracing.com/parts/ear-at165010erl/overview/
I used those and AN’d the whole thing
Forum:
Engine Swaps
09-13-2018, 09:22 PM
4
Ls3 air con setups
2,194
Posted By
ILLSMOQ
What Sports guy said. Pure automotive motec
Forum:
Engine Swaps
09-07-2018, 11:46 AM
181
Don't you hate it when you're texting and girl and her reply is " k "
53,078
Posted By
ILLSMOQ
Awesome stuff, for being a busy shop and...
Awesome stuff, for being a busy shop and developing these different swaps, you doing a great job covering all the bases. Keep it up! And thanks!
Forum:
Engine Swaps
08-14-2018, 10:50 AM
236
Mitsurugi: Reforged
51,794
Posted By
ILLSMOQ
Big difference between stacked plate and tube and...
Big difference between stacked plate and tube and fin. Get the stacked plate cooler.
Forum:
Engine Swaps
07-30-2018, 04:45 PM
23
Shop recommendations in SF Bay area to do a swap?
6,766
Posted By
ILLSMOQ
If you’re going motec, regardless of the motor,...
If you’re going motec, regardless of the motor, with the amount of tuning required after the swap is completed, shipping your car to Pure to have them do everything will save you lots money in the...
Page 1 of 9
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:45 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
