follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 5
1
2
3
4
5
Showing results 1 to 30 of 144
Search took
0.02
seconds.
Search:
Posts Made By:
86drift
Forum:
Engine Swaps
08-31-2016, 11:05 PM
21
Nissan v6
10,181
Posted By
86drift
This is better: ...
This is better:
http://i539.photobucket.com/albums/ff354/josh17m/14206094_1128521283882161_7410688695217523480_o_zps1m24k8wo.jpg
Forum:
Forced Induction
08-19-2016, 02:14 AM
19
Haltech elite
8,336
Posted By
86drift
I probably should have mentioned that's AUD not...
I probably should have mentioned that's AUD not USD.
$8000AUD is around $6100USD.
Forum:
Engine, Exhaust, Transmission
06-14-2016, 10:57 PM
18
Individual Throttle Body Development
6,906
Posted By
86drift
This is what it looks like with a DCOE pattern...
This is what it looks like with a DCOE pattern (ignoring the lip in the flange).
http://i539.photobucket.com/albums/ff354/josh17m/Mobile%20Uploads/20160611_133240_zps85i3aaco.jpg
Forum:
06-13-2016, 07:01 PM
18
6,906
Posted By
86drift
I'm currently deciding between DCOE, IDA and...
I'm currently deciding between DCOE, IDA and other throttle body designs. DCOE is cheap and easy to get. But throttle plates diameter is limited to 50mm. The centerline between plates is much smaller...
Forum:
06-12-2016, 07:36 PM
18
6,906
Posted By
86drift
I've make this thread to document the development of ITBs for our platform. After 4 yrs I've given up waiting for someone else to do it.
First things first. ITBs are unlikely to be a performance...
Forum:
04-05-2016, 07:44 PM
17
machine work for forged rods with stock pistons?
7,325
Posted By
86drift
A lot better than most which are 500+ ...
http://i539.photobucket.com/albums/ff354/josh17m/Rods_zpsvnv6qob6.png
Forum:
03-22-2015, 07:12 PM
27
Delete of Air Conditioning
13,418
Posted By
86drift
Chris did in fact use the factory parts as per...
Chris did in fact use the factory parts as per Diss's post:
SU003-00499
PULLEY ASSY, IDLER
SU003-00515
BRACKET, IDLER PULLEY
I'm keeping my AC even though it's a race car. Since the AC...
Forum:
AUSTRALIA
03-09-2015, 06:26 AM
0
Australian Toyota 86 Pro-Am Series
1,564
Posted By
86drift
In 2016 Australia is getting a one-make pro-am race series.
Toyota Australia website: http://toyota.com.au/86/pro-am
Offical FB page: https://www.facebook.com/toyotaracingaus
Non-official FB...
Forum:
02-19-2015, 09:54 PM
6
Fitting an additional O2 bung on Stock header?
1,755
Posted By
86drift
The primary O2 sensor is definitely good enough...
The primary O2 sensor is definitely good enough to tune with. I only got my LC1 so I could have a wideband gauge on the dash. I still tune using the standard O2 sensor output.
If you want to use...
Forum:
02-19-2015, 09:49 PM
6
1,755
Posted By
86drift
That's true. However the primary O2 isn't what...
That's true. However the primary O2 isn't what people refer to as either wide or narrow band. It'd kind of in the middle. I find it's within 0.5 of my LC1 and it only reads to 12:1 on the stock rom....
Forum:
02-19-2015, 01:52 AM
6
1,755
Posted By
86drift
I wouldn't bother. If your street tuning an NA...
I wouldn't bother. If your street tuning an NA the reading from the factory O2 sensor is good enough.
I run an LC1 in place of the second O2 sensor. Easy on catless headers/dump pipe. It's only...
Forum:
12-03-2014, 08:20 PM
19
Which LSD to take: Cusco or OS Giken
11,662
Posted By
86drift
I love it. 1.5 way is easy to drive on the limit...
I love it. 1.5 way is easy to drive on the limit and 5.1 gears makes for a noticeable improvement in acceleration.
Forum:
Software Tuning
06-10-2014, 11:46 PM
19
Transient ignition and knock count
9,842
Posted By
86drift
Too much and the car starts to stumble due to too...
Too much and the car starts to stumble due to too much fuel. I just added as much as I could whilst maintaining good driveability. It's varies with different intakes.
Forum:
Forced Induction
05-31-2014, 06:43 PM
28
For those with pieced together custom turbo kits..
9,743
Posted By
86drift
I DIY'd because it was cheap and I got exactly...
I DIY'd because it was cheap and I got exactly what I wanted.
There's no reason why you can't turbo your car without breaking the bank.
I used a manifold from a kit maker because it wasn't worth my...
Forum:
Software Tuning
05-22-2014, 07:01 PM
19
9,842
Posted By
86drift
The knock at 0.6/0.7 isn't transient knock....
The knock at 0.6/0.7 isn't transient knock. Typically happens in closed loop when driving up a steady hill. Try lowering the closed loop AFRs. Pulling timing doesn't help.
Forum:
Software Tuning
04-28-2014, 02:33 AM
9
AVCS tuning
4,215
Posted By
86drift
Doubt it. I've maxed out the values and haven't...
Doubt it. I've maxed out the values and haven't made a mess of my engine.
Forum:
Australia Classifieds
04-21-2014, 08:25 PM
7
WTB: factory GTS rear calipers
1,984
Posted By
86drift
Rear GT and GTS calipers are not the same....
Rear GT and GTS calipers are not the same. Different thickness discs.
Fronts are the same apart from the mount.
Forum:
03-27-2014, 09:36 PM
29
4.8 final drive
17,667
Posted By
86drift
I bought Cusco stuff. They have an LSD option...
I bought Cusco stuff. They have an LSD option that you can use Toyota 4.9 or 5.1 gears with. All up it was around $2k shipped to Australia. I did the install myself.
Videos aren't that useful for...
Forum:
03-26-2014, 10:29 PM
29
4.8 final drive
17,667
Posted By
86drift
I've got 5.1 and love it.
Forum:
12-12-2013, 12:34 AM
111
MAPerformance 68mm throttle body
38,102
Posted By
86drift
PM'd. I've got a tuned NA and all the gear needed...
PM'd. I've got a tuned NA and all the gear needed to test it.
Forum:
AUSTRALIA
07-23-2013, 09:00 AM
31
Festival of 86
9,521
Posted By
86drift
Festival of 86
The NSW 86/BRZ Car Club is pleased to announce our biggest event to date.
http://img96.imageshack.us/img96/2316/d0f3.jpg
Forum:
AUSTRALIA
05-25-2013, 06:16 PM
4
Headers
2,571
Posted By
86drift
The Borla headers do reduce the dip a little. But...
The Borla headers do reduce the dip a little. But just like all headers you'll need a tune to remove it completely.
I'm working on a tune ATM for my 4-1 race headers. Will post an update when it's...
Forum:
Forced Induction
05-14-2013, 03:23 AM
41
Turbo BRZ smashes a Supercharged v8 in a drag
16,277
Posted By
86drift
Not sure if it is back up and running. Last I...
Not sure if it is back up and running. Last I heard he wasn't chasing crazy numbers or 1/4 mile times.
For those wanting the highest hp 86 in Oz you'll need well over 300rwkw. That's the most I've...
Forum:
AUSTRALIA
05-02-2013, 03:39 AM
17
86/BRZ CAMS Affiliated Car Club
6,978
Posted By
86drift
It's more like 70+ :-D
Forum:
AUSTRALIA
05-02-2013, 03:32 AM
97
XForce Exhausts
64,767
Posted By
86drift
They come from the US. Normally 3-5 days.
Forum:
AUSTRALIA
04-09-2013, 09:27 PM
97
XForce Exhausts
64,767
Posted By
86drift
There's an 86 with the AVO Turbo kit getting the...
There's an 86 with the AVO Turbo kit getting the 3" XForce exhaust this week. I'll share pics/videos when I get them.
Forum:
AUSTRALIA
03-27-2013, 08:32 AM
97
XForce Exhausts
64,767
Posted By
86drift
I didn't try it with the UEL headers so I can't...
I didn't try it with the UEL headers so I can't be certain how loud it will be.
The 3" does give a deeper note.
I didn't notice any drone.
Forum:
03-27-2013, 08:26 AM
111
Borla UEL Header, any dynos yet?
49,626
Posted By
86drift
Actually I'm running EL headers. Got a CEL after...
Actually I'm running EL headers. Got a CEL after a few wks. Then installed the spacer and got one more CEL. But none for the last 4 months.
Forum:
AUSTRALIA
03-25-2013, 07:20 AM
97
XForce Exhausts
64,767
Posted By
86drift
Xforce 2.5" is the way to go if you plan on...
Xforce 2.5" is the way to go if you plan on installing cat-less headers. BTW, if you want to avoid a CEL with cat-less headers you can use one of
these...
Forum:
AUSTRALIA
03-23-2013, 06:18 AM
97
XForce Exhausts
64,767
Posted By
86drift
Here's the results from my dyno testing of some...
Here's the results from my dyno testing of some exhaust options.
The 3" XForce cat-back made 2.5% more torque and 2.2% more power.
The 2.5" XForce system (high flow cat pipe and cat-back) made 4%...
Page 1 of 5
1
2
3
4
5
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
04:20 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
