follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 65
Search took
0.55
seconds.
Search:
Posts Made By:
Spawn_Of_Creation
Forum:
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
02-29-2024, 08:28 PM
148
FRS/BRZ RALLY OR OFFROAD STYLE MEMBER COMPILATION
116,398
Posted By
Spawn_Of_Creation
Just as an FYI y'all, TBW just released a 5mm...
Just as an FYI y'all, TBW just released a 5mm thick rally skid plate, so now the Laile imported from japan isn't the only bolt on option, and now a much more affordable option exists.
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
08-11-2023, 03:44 PM
38
15 inch rims for winter?
28,670
Posted By
Spawn_Of_Creation
Guess i kinda derailed the thread a tiny bit, but...
Guess i kinda derailed the thread a tiny bit, but the 15x8+40 wheel fitment question still applies. This is for offroad or bad country road in sand or wet dirt where i don't want to sink in, not for...
Forum:
05-15-2023, 09:57 PM
148
116,398
Posted By
Spawn_Of_Creation
Wheel-it-fit https://wheel-it-fit.com It's...
It's like $5 to unlock it. otherwise there's a demo car that you can still get size differences and comparisons
Forum:
03-15-2023, 04:08 PM
148
116,398
Posted By
Spawn_Of_Creation
Another update: After driving on the lift, its...
Another update: After driving on the lift, its amazing. everything is much smoother, even slightly spirited is planted and the slight body roll made no difference.
I've now installed my a/t tires...
Forum:
02-26-2023, 10:46 PM
148
116,398
Posted By
Spawn_Of_Creation
Doing some questionable saw and hammer mods to...
Doing some questionable saw and hammer mods to fit the larger diameter tires. The setup on the fitment guide is for 215/65/16 on 16x7+30. Might need some verus steering limiter spacers for the inside...
Forum:
02-23-2023, 06:30 PM
148
116,398
Posted By
Spawn_Of_Creation
Update: Initial feel of the car after alignment...
Update: Initial feel of the car after alignment is basically like oem, but smoother (i'm guessing because of the shocks). The springs are frs oem rates, so nothing much has changed, but 1.5" taller....
Forum:
02-22-2023, 09:50 PM
148
116,398
Posted By
Spawn_Of_Creation
Just got my lift kit installed. I have yet to...
Just got my lift kit installed. I have yet to drive it properly as its currently in for alignment.
Bilstein B6, 1" Subtle Solutions spacers, 1.5" Subtle Solutions RA kit, Chuhatsu .5" lift springs,...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
01-27-2023, 08:28 AM
17
STI Rear Brembo
3,437
Posted By
Spawn_Of_Creation
Right, but what i mean is the caliper on the same...
Right, but what i mean is the caliper on the same front/back side of the rotor? The BRZ/FRS/GT86, the caliper is on the rear side of the rear rotor. If the sti caliper is on the front side of the...
Forum:
01-23-2023, 03:50 AM
7
Flatout Suspension Review
2,695
Posted By
Spawn_Of_Creation
I want to see the 3" lift. Most spacers only go...
I want to see the 3" lift. Most spacers only go to 2" tops.
Forum:
01-21-2023, 04:29 PM
14
Dual purpose street/rally cross coilovers
2,090
Posted By
Spawn_Of_Creation
When you lift, you need rear subframe spacers to...
When you lift, you need rear subframe spacers to adjust where the rear wheels sit in the wheel well. Having only coilovers to lift will mess with handling due to the angles.
Forum:
Engine, Exhaust, Transmission
01-16-2023, 01:19 AM
16
Any ideas why both of my cats failed?
2,102
Posted By
Spawn_Of_Creation
JDL cats are known for being low quality and...
JDL cats are known for being low quality and dissolving. Combine with a stage 2 tune that is designed for catless headers, and you probably killed them.
Forum:
Engine, Exhaust, Bolt-Ons
11-28-2022, 12:50 PM
8
FS: Ace A350 Header and overpipe
1,512
Posted By
Spawn_Of_Creation
This definitely looks used. You can even see the...
This definitely looks used. You can even see the wear marks where the header was rubbing on the under engine tray.
Forum:
10-26-2022, 04:02 PM
463
JDL 4-2-1 EL header
119,878
Posted By
Spawn_Of_Creation
Are you talking about Steve99?
Forum:
10-05-2022, 05:06 PM
84
Chuhatsu Plus MultiRoad lift springs
19,378
Posted By
Spawn_Of_Creation
You could always try the WTB section in the...
You could always try the WTB section in the classifieds.
Forum:
07-27-2022, 04:46 PM
79
Is ACE header discontinued? Anyone interested in making a replica?
14,603
Posted By
Spawn_Of_Creation
I have reason to trust Mike as CSG is the main US...
I have reason to trust Mike as CSG is the main US retailer for the ACE headers, as well as all the testing and experience they did with them.
Forum:
05-31-2022, 10:03 AM
39
Is there a good catted header?
5,437
Posted By
Spawn_Of_Creation
Might was well stick with stock. Catted headers...
Might was well stick with stock. Catted headers don't give you much hp if any.
Forum:
05-06-2022, 08:13 PM
79
14,603
Posted By
Spawn_Of_Creation
Not to mention that the only difference between...
Not to mention that the only difference between the 350, 250, and 150 are the overripe, and they are designed with the idea to be swappable for their designed use case at a cheaper install cost and...
Forum:
04-09-2022, 08:36 AM
18
ACT Clutch Lockout SOLVED
3,821
Posted By
Spawn_Of_Creation
os giken metal tool vs the softer plastic one...
os giken metal tool vs the softer plastic one that comes with the act clutches that can strip or not fit as tight against the metal splines.
Forum:
02-05-2022, 11:10 AM
3
Ceramic coating on header mating surface?
600
Posted By
Spawn_Of_Creation
Ditto for my Ace header.
Forum:
01-13-2022, 05:42 PM
203
Gauging interest - RCE Rally-x springs
52,087
Posted By
Spawn_Of_Creation
Monthly bump/update?
Forum:
12-21-2021, 10:17 PM
20
Exhaust is too loud
3,931
Posted By
Spawn_Of_Creation
The front pipe is probably where you are getting...
The front pipe is probably where you are getting most of the cabin noise from. If you swap that back to stock, it should quiet down a lot.
That said, the CSG Touring 86 catback should also help...
Forum:
11-29-2021, 08:52 AM
3
Diff mounts
771
Posted By
Spawn_Of_Creation
Looks like they were probably installed...
Looks like they were probably installed incorrectly, or you had a defect. I've been using them for 2 years now no issues.
Forum:
09-30-2021, 01:58 PM
11
Best option to lift: spacers, coil overs, airbags?
1,561
Posted By
Spawn_Of_Creation
Can you do this on stock suspension? Or does it...
Can you do this on stock suspension? Or does it require a slight lift? I'm currently on 215/55/16 on 16x7+30 Method MR502 Rally Spec with stock suspension.
Forum:
09-30-2021, 01:49 PM
11
1,561
Posted By
Spawn_Of_Creation
Lift spacers are the budget way to go. There are...
Lift spacers are the budget way to go. There are 2 common lift springs available (TRD and Chuhatsu Plus Multiroad), with a 3rd in the works (RCE Rally X [I'm waiting on these for the spring rates])....
Forum:
Brakes, Suspension, Chassis
04-12-2021, 03:50 PM
11
Chuhatsu Multi Road Lift Springs - $200 shipped
1,788
Posted By
Spawn_Of_Creation
Lol that's what i thought when i saw them do that.
Forum:
03-21-2021, 05:08 AM
203
52,087
Posted By
Spawn_Of_Creation
I'm pretty much ready for these to drop. Ive...
Ive got Bilstein B6 shocks, with new top hats, boots and rear bump stops, 1" Subtle Solutions aluminum lift kit + 1.5" rear alignment kit, SPL Camber...
Forum:
03-18-2021, 04:25 AM
158
Bilstein B6 and B8 explained
35,321
Posted By
Spawn_Of_Creation
Rally X spring. For loose surfaces. Roughly ½"...
Rally X spring. For loose surfaces. Roughly ½" lift.
Forum:
02-13-2021, 02:56 PM
5
IS 250 y32 3.73 LSD for FI application
890
Posted By
Spawn_Of_Creation
The ones we want (LSD) are marked with axle code...
The ones we want (LSD) are marked with axle code stickers M98 and M85. The M98 is from an automatic IS300, and is a 3.9 final drive ratio. The M85 is from the manual and is 3.7
Forum:
02-13-2021, 02:52 PM
5
890
Posted By
Spawn_Of_Creation
you can try contacting Wier Performance and see...
you can try contacting Wier Performance and see if they have any available
Wier Performance (http://www.weirperformance.com/finaldrivegears.html)
Forum:
02-13-2021, 05:45 AM
18
Stock ride height is not too bad for the dirt...
2,786
Posted By
Spawn_Of_Creation
Have you thought about running winter or a/t? ...
I've got a set of Method MR502 16x7 I plan to run with 215/65/r16 Grabber or K02. I'm waiting on the RCE Rally-X springs though. I'll probably need...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:56 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
