Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 357
Search took 2.75 seconds.
Search: Posts Made By: Element Tuning
Forum: Tracking / Autocross / HPDE / Drifting 06-15-2018, 05:06 PM
Posted By Element Tuning
I agree and that's my point. Your class rules...
I agree and that's my point. Your class rules make it so that tire is the fastest based on the points penalty or if the class has treadwear rules. For the TT class I run there's no points, just...
Forum: Engine, Exhaust, Transmission 06-15-2018, 04:34 PM
We tested the Reimax 12mm gear and not the 14mm...
We tested the Reimax 12mm gear and not the 14mm Reimax gear. Remember though we tested the 14mm WRX DIT oil pump. It probably would have been better if Reimax copied the BRZ pump rotor design but I...
Forum: Engine, Exhaust, Transmission 06-12-2018, 06:04 PM
Wish we had something we could sell other than an...
Wish we had something we could sell other than an full engine build or an LS swap ;)
Thicker oil helps but only marginally. Run an oil weight that suits your operating temperature. If you're a...
Forum: Engine, Exhaust, Transmission 06-12-2018, 02:35 PM
Be careful here as there was a complete redesign...
Be careful here as there was a complete redesign I believe to help with the rocker ejection that included longer valve stems, different rockers, and different pivots. I believe that was in an effort...
Forum: Engine, Exhaust, Transmission 06-12-2018, 02:19 PM
Been a long time guys since I've been on any...
Been a long time guys since I've been on any forums but I'll revisit some results.
The Remax gear was worse than OEM for us. The design resulted in lower oil pressure in the peak TQ areas and...
Forum: Tracking / Autocross / HPDE / Drifting 09-07-2017, 01:26 PM
Glad you welded that lower mount as the body is...
Glad you welded that lower mount as the body is too weak to bolt there. We actually made a weld down plate with backing nuts so you could still bolt in and remove the cage. It might be a better...
Forum: Tracking / Autocross / HPDE / Drifting 05-17-2017, 02:59 PM
If you pull the fuse you'll have an impossible...
If you pull the fuse you'll have an impossible time turning the car just like when the system shuts down. You either reduce your caster as I'm assuming you've added some or you build a cooler. I...
Forum: Tracking / Autocross / HPDE / Drifting 05-09-2017, 03:40 PM
Oh I had a huge problem with shutting off under...
Oh I had a huge problem with shutting off under trail braking (at least 3 turns a lap). It does make it hard to drive a consistent line when you go from barely holding the whee to straight up man...
Forum: Engine, Exhaust, Transmission 05-07-2017, 02:49 PM
Yes you have to clearance the rods to run those...
Yes you have to clearance the rods to run those pistons but also the tops need to be machined some and the DI pocket isn't correct for the FA20 direct injection.
While I made it work, it was...
Forum: Engine, Exhaust, Transmission 05-01-2017, 06:36 PM
Thanks! Our motor build gets the oil pressure up...
Thanks! Our motor build gets the oil pressure up but I'm sure the Accumulator kit has helped with cornering Gs as we've seen over 2G with our Time Attack FRS. It's cheap insurance for sure!!!
Forum: Engine, Exhaust, Transmission 04-27-2017, 07:38 PM
You have to split the cases so as long as a full...
You have to split the cases so as long as a full build which is about 27 hours.
Forum: Engine, Exhaust, Transmission 04-25-2017, 01:37 PM
Updates after 1.5 years of racing
I know it's been forever since I've updated anything or even been on the forums. Honestly we have just been busy with engine building, client builds, and new projects. We also had been racing with...
Forum: Tracking / Autocross / HPDE / Drifting 04-25-2017, 12:51 PM
Hahaha I don't get messages anymore sorry. ...
My Autopower was not welded in, I had plates welded down, and then I bolted to those. They just cut off what they had to but yes any additional labor...
Forum: Engine, Exhaust, Transmission 03-06-2016, 10:19 AM
Wrong. You use the oil viscosity required for...
Wrong. You use the oil viscosity required for whatever conditions the engine is being used in or used for. If you have a stock engine, oem power, and the car is daily driven then by all means use...
Forum: Engine, Exhaust, Transmission 03-02-2016, 03:37 PM
I am currently running the OEM oil pump with an...
I am currently running the OEM oil pump with an Element Tuning Pro Comp Engine package as I have always been with the exception to the one race where I tested the aftermarket oil pump gear.
The...
Forum: Tracking / Autocross / HPDE / Drifting 03-02-2016, 03:23 PM
Well I have 17 seconds a lap more car ;)
Forum: Engine Swaps 03-01-2016, 10:45 PM
We are building an EZ30 for both of our race cars...
We are building an EZ30 for both of our race cars but implementation into the FRS is only coming after I finish up with the last R&D stages of the FA20. We've made 900 hp with an EZ30 and Hydra EMS...
Forum: Tracking / Autocross / HPDE / Drifting 03-01-2016, 06:11 PM
Track: NOLA Motorsports Park Car: Element...
Car: Element Tuning Time Attack FR-S
Mods: Element Tuning Pro Comp Motor 10.5 Compression with Big Valve Heads (9k RPM)
Element Tuning Hydra EMS Stand-Alone with...
Forum: Engine, Exhaust, Transmission 03-01-2016, 05:40 PM
I wouldn't overlook the potential this is a valve...
I wouldn't overlook the potential this is a valve rocker arm coming apart. Been there and done that unfortunately. Before a catastrophic failure the pin rocks partially out and it effects the valve...
Forum: Engine, Exhaust, Transmission 02-24-2016, 09:42 PM
https://s-media-cache-ak0.pinimg.com/736x/9c/40/7c...
https://s-media-cache-ak0.pinimg.com/736x/9c/40/7c/9c407ccf9b7672a63f5b9b8524884990.jpg
Forum: Engine, Exhaust, Transmission 02-24-2016, 08:54 PM
Well most superchargers don't make near the power...
Well most superchargers don't make near the power or torque compared to the turbo kits on the market so oil pressure demands aren't really as high.
What I would do and recommend would make your...
Forum: Engine, Exhaust, Transmission 02-24-2016, 08:49 PM
Not really following you. With an external...
Not really following you. With an external pressure stage the oil pump sucks oil from the dry sump tank. Most lines are rated for high pressure and not high vacuum and therefore they can and do...
Forum: Engine, Exhaust, Transmission 02-24-2016, 12:41 PM
We are working on new NA high RPM heads as we...
We are working on new NA high RPM heads as we speak :)
Forum: Engine, Exhaust, Transmission 02-23-2016, 03:34 PM
I have stock cams and 9k RPM :) Just takes the...
I have stock cams and 9k RPM :) Just takes the right engine build.
https://www.instagram.com/p/BB79YZwNvWO/?taken-by=elementtuning
Forum: Engine, Exhaust, Transmission 02-23-2016, 12:20 PM
Test it for the community and let us all know how...
Test it for the community and let us all know how it worked out.
Forum: Engine, Exhaust, Transmission 02-22-2016, 06:37 PM
Wow it's been a really long time since I've...
Wow it's been a really long time since I've updated this thread and where do I even start? First...
Ok has anyone else tried the Remax gear or am the only one holding the torch here? I really...
Sorry if you've left multiple messages and emails...
Sorry if you've left multiple messages and emails and we didn't get them. I tried to dig up any emails with FA20, BRZ, or FRS builds and I just couldn't find any we haven't replied to. I know how...
Forum: FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 08-21-2015, 07:32 PM
Yeah so the RR kit balances the brakes pretty...
Yeah so the RR kit balances the brakes pretty well so I think most should try something like that first. The next step would be to try to plumb a pedal box with dual masters into the ABS system or...
Forum: FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 08-20-2015, 01:36 PM
Sorry for the late replies as I was out of the...
Sorry for the late replies as I was out of the country getting a little R&R. Grass Roots Motorsports Magazine released the full lap video of the BC Racing Element Tuning FRS at UTCC VIR.
Forum: FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 08-14-2015, 09:12 AM
Thanks! Check our YouTube channel for full...
Thanks! Check our YouTube channel for full videos.
I actually have the NASA TT2 lap record at VIR with a 1:58 in this FRS. We had the car way detuned to get through the event in one piece. ...
