follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 85
Search took
0.56
seconds.
Search:
Posts Made By:
KoolBRZ
Forum:
Forced Induction
08-01-2016, 06:29 PM
1,206
Phantom FTS Electric Supercharger Owners Thread
357,964
Posted By
geezerbrzeezer
While this is currently factually correct,...
While this is currently factually correct, V-CMunk .1 is currently testing.
Advantages:
A chipmunk has pouches inside its cheeks, which it typically uses for storing food while foraging. After...
Forum:
Forced Induction
08-01-2016, 04:10 PM
1,206
357,964
Posted By
stevo585
Wow how do you have so much boost? That's the V2...
Wow how do you have so much boost? That's the V2 TQ250 right?
Forum:
Software Tuning
07-31-2016, 04:32 PM
274
AVCS - Intake and Exhaust Timing
109,554
Posted By
shr133
Some of the stock setting are too high,...
Some of the stock setting are too high, especially the exhaust cam, too much exhaust cam is for egr effect and makes the engine flat....
So reducing the cam timing and smoothing the map make the...
Forum:
Software Tuning
07-19-2016, 04:57 PM
2,150
Sticky:
Data Logs! Post them here.
503,194
Posted By
Kodename47
I have probably got the definition in metric if...
I have probably got the definition in metric if needed.....
Forum:
Forced Induction
07-13-2016, 09:00 PM
11,295
Full throttle Electric Supercharger Build Thread
3,410,048
Posted By
Target70
I just wanted to note that this was an auto vs...
I just wanted to note that this was an auto vs manual, so different rear end gearing I believe. That being the case I don't know how much the estimated 5 to 7 second lead would change if they were...
Forum:
Forced Induction
06-26-2016, 03:28 AM
220
PROcede ESC User Software!
71,258
Posted By
keen as
That all makes sense. KoolBRZ I don't expect...
I don't expect any difference between 5.21v and 4.95V. After I get my dump pack back in, I'll log boost to see if there is any change when I switch from procede to...
Forum:
Forced Induction
06-25-2016, 11:51 PM
220
71,258
Posted By
keen as
NO, that post describes an an UNcalibrated...
NO, that post describes an an UNcalibrated throttle. In the zero rpm row, I populated the 80 and 85 column cells with "100". That was the only change in the map and I attached the picture showing...
Forum:
Forced Induction
06-25-2016, 03:59 AM
220
71,258
Posted By
keen as
KoolBRZ I had spare time to do some...
KoolBRZ
I had spare time to do some measurements.
I think they may be unreliable. Currently, my Dump pack is out of the car and the batteries are getting tested. While I am able to test the signal...
Forum:
Forced Induction
06-22-2016, 12:16 AM
220
71,258
Posted By
keen as
I tested both original (non throttle calibrated)...
I tested both original (non throttle calibrated) map and then calibrated map. The problem (described previously of less boost) only occurs after throttle calibration.
Forum:
Software Tuning
06-17-2016, 07:01 AM
274
109,554
Posted By
Matt@Cosworth
there's a couple reasons 1) as the engine speed...
1) as the engine speed increases air velocity in the port also tends to increase, so where the air is entering the cylinder can change slightly and this leads to different...
Forum:
Software Tuning
06-15-2016, 05:35 PM
274
109,554
Posted By
Matt@Cosworth
if you change the inlet cam timing then the...
if you change the inlet cam timing then the injection timing should travel with it, on very highly tuned engines ( F1) with pfi the injection timing map varies by 200 degrees
the gains are small...
Forum:
Software Tuning
06-13-2016, 07:29 PM
10
URGENT!!! CAR WONT TURN OVER!
4,757
Posted By
Jaden
I've had this happen, there is an auto recover...
1) disconnect the battery
2) depress the brake pedal for several seconds to drain any residual energy.
3) reconnect the battery.
4) reflash.
I'm pretty sure that's what I ended up...
Forum:
Engine, Exhaust, Transmission
03-13-2016, 02:41 PM
3
AVCS Explained
3,384
Posted By
Rennmeister
AVCS Explained
http://www.vikingspeedshop.com/subaru-avcs-explained/
Info about AVCS, including Dual AVCS, and how it's beneficial.
Forum:
02-25-2016, 09:34 AM
36
FR-S Gear Ratio Comparison
54,793
Posted By
Icecreamtruk
KoolBRZ sumarized really well. Btw, I have a MT...
KoolBRZ sumarized really well. Btw, I have a MT with EL headers, full exhaust and tuned. I can HEAR the difference when there's different weather (specially going from not only from wet/dry but...
Forum:
BRZ First-Gen (2012+) -- General Topics
01-03-2016, 07:08 PM
30
Is anyone else out there a Snooligan, (Snow Hooligan)?
4,918
Posted By
zman
He forgot to say filmed in mexico Sent...
Forum:
Software Tuning
12-20-2015, 04:34 PM
274
109,554
Posted By
ztan
Greddy T518Z turbo. Base maps similar, Safe and...
Greddy T518Z turbo. Base maps similar, Safe and Normal identical.
Forum:
Software Tuning
12-19-2015, 02:27 PM
274
109,554
Posted By
ztan
Just had a look at the disassembly. There is...
There is an interpolating factor at FFF89C88 (A01G) which is used to interpolate between AVCS Intake Base table and the return from AVCS Intake Safe/Normal...
Forum:
Software Tuning
12-12-2015, 02:40 AM
270
PI : DI Ratio Discussion
74,501
Posted By
steve99
Yes they are the tables for closed loop, read the...
Yes they are the tables for closed loop, read the table properties in romraider, dont put 0 or positive values in as weird stuff happens and ecu ignors fuel trim compensations kind of open loop all...
Forum:
Software Tuning
12-08-2015, 12:09 AM
270
74,501
Posted By
steve99
After a couple of tests settled on ratios as...
After a couple of tests settled on ratios as below. Made the 3200 line 100% DI as this is arround where the last ltft correction is done (maf arround 3V) and after that your using DI exclusively...
Forum:
Software Tuning
12-05-2015, 10:14 AM
270
74,501
Posted By
arghx7
You're giving Subaru too much credit. It's not...
You're giving Subaru too much credit. It's not that smart, or at least, not that anyone has proven. Unless someone here wants to link to somewhere showing the load estimation being related to fuel...
Forum:
Software Tuning
12-02-2015, 03:59 AM
274
109,554
Posted By
Kodename47
Resurrected this old spreadsheet of mine: AVCS...
AVCS Viewing/Comparison Tool (https://dl.dropboxusercontent.com/u/70894411/GT86OwnersClub/Map%20Calculators/AVCS%20Comparison.xlsx)
Paste in your own...
Forum:
Software Tuning
12-01-2015, 10:54 PM
274
109,554
Posted By
arghx7
cross posting from the other thread: The...
The AVCS intake side has the negative values thambu19 and others were talking about because it is a mid lockpin AVCS. That means the intake side can retard,...
Forum:
Software Tuning
12-01-2015, 10:51 PM
270
74,501
Posted By
arghx7
I'm not too active on this forum lately but I did...
I'm not too active on this forum lately but I did get caught up with this thread, as these things tend to die and suddenly get revived.
The AVCS intake side has the negative values thambu19 and...
Forum:
Software Tuning
11-29-2015, 10:23 AM
274
109,554
Posted By
solidONE
Now, I know this thread is about cam timing and...
Now, I know this thread is about cam timing and not fueling but since it was mentioned in this thread about having the AFR set to as rich as 11.8 I would like to address it here. I will move it if...
Forum:
Software Tuning
11-27-2015, 06:49 PM
13
Quick questions about OFT
3,730
Posted By
thambu19
I wish everything was open source Sent from...
Sent from my HTC One_M8 using Tapatalk
Forum:
Software Tuning
11-25-2015, 02:00 PM
270
74,501
Posted By
thambu19
Hey budd I will take a look. Always remember that...
Hey budd I will take a look. Always remember that cams and spark have to go together. Any cam change will need a change in spark timing. I am no expert by any means. I do engine development and...
Forum:
11-23-2015, 03:28 AM
31
Automatic Gear Ratio change
16,386
Posted By
FRS Justin
Ok heres a quick run down on auto trans gearing....
Ok heres a quick run down on auto trans gearing. Its not like a manual where you have to gears running together to make a ratio, To change a autos gears you would need different clutch hubs, pinions,...
Forum:
11-23-2015, 03:16 AM
31
16,386
Posted By
AceHeader-MT
For reference, here's a video of an AT with 5.1...
For reference, here's a video of an AT with 5.1 FD and Delicious E85 tune/kit.
Shift points are pretty good and still can drive on highway. Car is on 17" wheels with 235/40 tires.
Start video...
Forum:
Software Tuning
11-22-2015, 10:27 PM
270
74,501
Posted By
thambu19
When you get a chance can you try something like...
When you get a chance can you try something like this? At WOT I have gone 100% DI. This means you need to a degree or so more spark there to use the full potential. If you do not then it will feel...
Forum:
Software Tuning
11-19-2015, 03:26 AM
270
74,501
Posted By
Kodename47
KoolBRZ if you want full ratio control above...
KoolBRZ if you want full ratio control above idle, don't worry about the max/min ratio just set the load and RPM thresholds to around 1000/0.2. In your setup, the 5% DI will run no PI at all,so in...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:36 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
