follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 111
Search took
3.40
seconds.
Search:
Posts Made By:
ZZT86
Forum:
Issues | Warranty | Recalls / TSB
07-10-2019, 08:21 AM
24
Rattle/knocking from engine (video)
3,821
Posted By
ZZT86
If you press clutch in does it go away ? Hot idle...
If you press clutch in does it go away ? Hot idle revs are pretty low causing some vibration which transmits to the rest of the driveline including clutch & flywheel which are known to rattle...
Forum:
Engine, Exhaust, Transmission
05-23-2019, 07:01 AM
62
(Yet another) quick UEL header question.
9,433
Posted By
ZZT86
Guru_woodman Thank you for your input re this &...
Guru_woodman Thank you for your input re this & yes I got you. I know it's an OF problem which is why I just tried going back to an older version of "Manager" to see if anything would change but it...
Forum:
05-20-2019, 12:18 AM
37
Oil temps rising for no reason
7,337
Posted By
ZZT86
@thinkV...
@thinkV (https://www.ft86club.com/forums/member.php?u=152206)
Where in oz are you ? Have you mentioned this to whomever built your engine/setup ? I'd wonder if the thermostat on that oil cooler...
Forum:
AUSTRALIA
10-17-2018, 08:06 AM
7
Diff oil service
4,671
Posted By
ZZT86
^ Sweet, Penrite ProGear looks a good oil that...
^ Sweet, Penrite ProGear looks a good oil that matches the Toyota LX spec - full synth too ;)
Forum:
07-12-2018, 10:39 PM
58
DIY Timing cover leak repair?
24,124
Posted By
ZZT86
humfrz - good pickup on that typo, it was the...
humfrz - good pickup on that typo, it was the timing chain cover edge which wept slightly & hey you're 100% correct - if it works it works, only cost me a few bucks in RTV :cheers:
Forum:
07-12-2018, 09:45 PM
58
24,124
Posted By
ZZT86
Cam Leak Repair
My car was out of warranty so I jacked the front up, left it for a few days so oil could drain away from timing chain cover, cleaned it all up real good, applied automotive RTV in layers over several...
Forum:
05-14-2018, 09:26 PM
57
Advice required: Spun out rod bearings.
28,069
Posted By
ZZT86
Out of curiosity how hard did you push ? If...
If there's more of that to come then I would highly recommend an oil temp gauge at least & keep temps under 250F, an oem oil cooler will help.
Forum:
09-12-2017, 08:45 PM
70
Stock engine blown, warranty denied, anyone taken this to court?
18,465
Posted By
ZZT86
Fair comment, personally I judge a cars quality...
Fair comment, personally I judge a cars quality by the number of times I have to take it back because something don't work/look right or has failed altogether. A good & willing dealer/manufacturer...
Forum:
09-12-2017, 08:25 PM
70
18,465
Posted By
ZZT86
Corectamundo !
Corectamundo !
Forum:
09-12-2017, 04:56 AM
70
18,465
Posted By
ZZT86
^^ Unfortunately for your boss she has purchased...
^^ Unfortunately for your boss she has purchased an even more problematic car than the Outback :/ I have heard that the Subaru Boxer is renowned for oil consumption, how much depends on how it was...
Forum:
06-01-2017, 11:23 PM
186
Very loose rear end (Handling)
40,447
Posted By
ZZT86
^^ that's too funny :lol:
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
12-13-2016, 03:44 AM
26
Hot lava tail light ideas
8,511
Posted By
ZZT86
http://www.ft86club.com/forums/showpost.php?p=2580...
http://www.ft86club.com/forums/showpost.php?p=2580016&postcount=353
Forum:
11-29-2016, 03:00 AM
26
8,511
Posted By
ZZT86
How about red crystal eyes ?
Forum:
10-26-2016, 07:00 AM
16
OEM armrest elbow question
4,417
Posted By
ZZT86
Agree with others here - the OEM armrest/lid is...
Agree with others here - the OEM armrest/lid is perfect, should be stock fitment damn it.
Forum:
10-26-2016, 06:57 AM
371
Oil Leaking??
145,301
Posted By
ZZT86
I have black ceramic coated headers on mine (much...
I have black ceramic coated headers on mine (much much cooler than stock) & I still got that leak you mentioned ;) I tightened the damn thing & cleaned it & appears OK at this stage.
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
10-26-2016, 06:53 AM
378
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40
305,321
Posted By
ZZT86
Before camber bolts went on I had a mountain of...
Before camber bolts went on I had a mountain of clearance - about 10mm from memory, so -1.5deg neg camber @ that wheel height made quite a difference for me. +45 will push the inner mounting face...
Forum:
Electronics | Audio | NAV | Infotainment
07-11-2016, 09:18 PM
10
AVH-4200NEX/AVH-8850BT Problems
2,447
Posted By
ZZT86
Fusrs? Did you test unit off car ?
Forum:
DIY (Do-It-Yourself) Guides
06-30-2016, 07:21 AM
591
Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!)
415,239
Posted By
ZZT86
Nice job, well done ;)
Forum:
Australia Classifieds
06-16-2016, 06:35 AM
41
ACQUIRED - STI Axle Back exhaust
14,671
Posted By
ZZT86
I used to have the Perrin/unresonated and thought...
I used to have the Perrin/unresonated and thought it sounded pretty good with stock manifold but as soon as I went uel that all went out the window :confused0068: beautifully made too.
As for STI...
Forum:
04-19-2016, 05:46 AM
60
Exhaust note nearly perfect... But can you help me bring down the volume?
11,270
Posted By
ZZT86
I presume OP has the stock midpipe with the...
I presume OP has the stock midpipe with the resonator ? It does sound very loud with a supposedly quiet SP Elite axle back.
Forum:
03-29-2016, 06:38 AM
41
14,671
Posted By
ZZT86
I have no intentions of paying top dollar for it...
I have no intentions of paying top dollar for it buddy - any way you look at it simply ain't worth the coin they ask for it ;)
Forum:
03-28-2016, 07:49 AM
15
Removing Headliner?
13,099
Posted By
ZZT86
I shoved deadener & then some 12mm acoustic foam...
I shoved deadener & then some 12mm acoustic foam liner in there & there's plenty of room for all this . . . much more solid & quieter now.
Forum:
AUSTRALIA
03-16-2016, 05:07 AM
32
Harrop Supercharger
18,551
Posted By
ZZT86
I too got that same email. Dyno looks interesting...
I too got that same email. Dyno looks interesting although no figures below 2500rpm & they passed EPA using a stock header . . . . see attached dyno chart.
I wish I had the moula to splurge on...
Forum:
01-08-2016, 05:23 AM
591
415,239
Posted By
ZZT86
2016 WRX/FXT Oil Cooler
Job Done & by jingo I like !
What's different here? The oil cooler itself is the latest version used in the current 2016 Rex part# 21311AA180 & although angle of exit pipe not perfect it fits...
Forum:
12-02-2015, 05:15 AM
616
Clutch pedal loud squeak
235,240
Posted By
ZZT86
3 months ago I cleaned/lubed the point where the...
3 months ago I cleaned/lubed the point where the slave actuator rod meets the clutch fork & it worked a treat . . . . up until now :/ Strange thing is that it's stopped squeaking again but I'm sure...
Forum:
11-13-2015, 05:54 AM
48
Gotta love it RETRO - Rota RKR 18x9.5 ET44 255/35/18
16,358
Posted By
ZZT86
JoeHK - Pics are a bit dark/taken in shade...
JoeHK - Pics are a bit dark/taken in shade otherwise they look great ! Put some matt tyreshine on & shove it in the sunlight & be amazed. Nice.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
11-13-2015, 05:31 AM
15
Alignment Specs - Eibach Sportline Springs
6,282
Posted By
ZZT86
@zkahle...
@zkahle (http://www.ft86club.com/forums/member.php?u=47761) - I'm happy for you bud & I don't doubt the springs effectiveness at controlling bounce for the most part but what I'm talking about is...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
11-10-2015, 02:57 AM
383
Change your manual transmission fluid ASAP!!!
204,588
Posted By
ZZT86
After quite some time on the Gear300 I decided to...
After quite some time on the Gear300 I decided to dump it & put back in the Pentosin MTF2 (filtered - previously done 3000kms) paying special attention to the quantity going in - measured exactly...
Forum:
11-05-2015, 03:58 AM
157
E85 specific oil
76,642
Posted By
ZZT86
3rd consecutive UOA for TGMO 0W20 SN GF5 -...
3rd consecutive UOA for TGMO 0W20 SN GF5 - 7047kms on oil E85 use only ! I'm stoked & satisfied the oil can easily go the distance, new oil/oil filter/air filter installed (all genuine parts) after...
Forum:
10-16-2015, 04:08 AM
157
E85 specific oil
76,642
Posted By
ZZT86
VOA / UOA for TGMO 0W20 SNGF5 - E85 only
Thought I'd share this with you all since it's something worth looking at & certainly something the guys over @ Bitog land would get excited about ;)
Attached are VOA & 2 x UOA for Toyota TGMO...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:12 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
