follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 52
Search took
0.02
seconds.
Search:
Posts Made By:
d1ck
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
11-30-2015, 10:18 PM
38
Someone tried to steal my wheels. Can't remove wheel locks.
9,108
Posted By
d1ck
Lots of the advice here will result in damaged...
Lots of the advice here will result in damaged wheels. You need to buy a kit like this one:
http://www.princessauto.com/en/detail/powerfist-4-pc-locking-wheel-nut-remover-set/A-p8320954e
It's...
Forum:
Engine, Exhaust, Transmission
07-05-2015, 03:18 PM
44
FIXED-CX Racing sandwich plate literally pouring out oil
13,281
Posted By
d1ck
If they can't make a sandwich plate that doesn't...
If they can't make a sandwich plate that doesn't leak, do you really want to keep their lines and heat exchanger on your car? I'd throw it all in the trash and buy a kit that's not garbage.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
04-28-2015, 09:12 AM
28
GodSpeed Mono Max coilcover review
38,291
Posted By
d1ck
Am I the only one who thinks this sounds like it...
Am I the only one who thinks this sounds like it was written by someone at Godspeed? I have nothing to base this on, just a vibe I got when reading.
Forum:
12-16-2014, 11:42 AM
24
Decompressing stock springs by jacking?
8,457
Posted By
d1ck
You can stand it up on the floor and have someone...
You can stand it up on the floor and have someone lean on the mount while you take off the top nut.
Forum:
Software Tuning
10-02-2014, 11:04 AM
136
Interesting Findings on the Dyno - OpenFlash/Vishnu tuned
48,869
Posted By
d1ck
If it was an extended pull the load on the engine...
If it was an extended pull the load on the engine is higher, and it's possible that this increased load is causing some knock at that RPM / Load.
Forum:
Software Tuning
08-14-2014, 11:31 AM
1,062
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download
330,204
Posted By
d1ck
Yes. If I apply heavy throttle below 2000RPM the...
Yes. If I apply heavy throttle below 2000RPM the car bogs very badly and starts bucking.
Forum:
Software Tuning
08-13-2014, 07:26 AM
1,062
330,204
Posted By
d1ck
I too have the bogging problem. I was pulling out...
I too have the bogging problem. I was pulling out of a gas station across two lanes when I noticed a car approaching quicker than I thought. "No problem I thought, I'll just apply more throttle and...
Forum:
Tracking / Autocross / HPDE / Drifting
07-28-2014, 01:00 PM
25
Balance
5,069
Posted By
d1ck
Thought I'd post an update for those who offered...
Thought I'd post an update for those who offered me advice. I removed the Strano FSB and installed the stock one. The car is much better now. I may actually add a bit more rear toe in as I find the...
Forum:
07-21-2014, 10:15 AM
25
Balance
5,069
Posted By
d1ck
Thank you for the input. I actually made a...
Thank you for the input. I actually made a mistake in my post and right now I have the stiffer springs in the rear, and softer in the front. However, I'm going to try removing the Strano bar and...
Forum:
Software Tuning
07-10-2014, 03:47 PM
37
OP2 logging discussion
22,566
Posted By
d1ck
This worked using the following scale:
Forum:
03-10-2014, 09:07 AM
19
Dunlop Z2's Chunking, Defective?
7,331
Posted By
d1ck
I've heard of the ZII's chunking before from RR...
I've heard of the ZII's chunking before from RR guys, so it's not unheard of.
Forum:
12-12-2013, 08:44 PM
29
Poll:
Front lower control arms, which set would you want?
7,257
Posted By
d1ck
You realize that the arms that are on the car now...
You realize that the arms that are on the car now are stamped metal, right? Maybe you didn't because nobody ever sees them. The control arm is there for one purpose only, and it's not to look pretty.
Forum:
12-09-2013, 09:08 AM
54
Scion FR-S Lift kit
33,876
Posted By
d1ck
Going with taller springs would be a much better...
Going with taller springs would be a much better option IMO. They would give you more bump travel and ground clearance. I wonder if there are any Impreza springs that would do the job?
Forum:
10-24-2013, 07:35 AM
62
1300hp capable 6 speed swap who is interested?
17,891
Posted By
d1ck
This is a little off topic, but why do companies...
This is a little off topic, but why do companies always rate their drivetrain parts in HP and not torque? A torque rating would be a much better indication of the strength of the unit.
Forum:
10-17-2013, 08:14 PM
10
HELP kw coilover top hat install problem
5,882
Posted By
d1ck
I think the KW's have a 7mm hex on the end of the...
I think the KW's have a 7mm hex on the end of the shock shaft. You need to use a pass through socket driver for the top nut while using a 1/4" Drive 7mm ratchet to hold the shaft in place.
Forum:
09-09-2013, 07:47 AM
105
Is going all catless on a na fa20 motor such a good idea?
25,816
Posted By
d1ck
Bingo. The ideal exhaust system would in theory...
Bingo. The ideal exhaust system would in theory have a constantly decreasing diameter with a few bends as possible. It would also have no restrictions such as cats present; which slow down the...
Forum:
08-19-2013, 12:33 PM
6
02 Sensor Socket Size?
7,005
Posted By
d1ck
Most O2 sensors are 22mm / 7/8". I've never taken...
Most O2 sensors are 22mm / 7/8". I've never taken the sensor out of the twins but I'd bet that it's the same size.
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
08-12-2013, 12:58 PM
30
Tire rack rates Michelin SS top again
6,370
Posted By
d1ck
All the tires he listed will be faster than the...
All the tires he listed will be faster than the PSS. The PSS is a great all round tire, but they're not in the same class as ZII, Rival, RE-11A, AD08, RS3
Forum:
08-02-2013, 12:20 PM
89
3rd-4th gear grind...but only near redline
28,132
Posted By
d1ck
Your other car is a DSM man, you should know all...
Your other car is a DSM man, you should know all about transmission issues.
Forum:
07-01-2013, 10:02 PM
0
Rear Suspension Video (Look at diff bushings!)
1,269
Posted By
d1ck
VMI 2013 Points Event #4 - Atkinson - Run 3 - Rear Suspension - YouTube
This is a video I took at yesterday's autocross. As you can see there's a lot of movement in the diff bushings but the...
Forum:
Forced Induction
06-21-2013, 04:55 PM
11,295
Full throttle Electric Supercharger Build Thread
3,413,777
Posted By
d1ck
If they ever get thermo-electric generators cheap...
If they ever get thermo-electric generators cheap enough to use in automotive applications these could be a viable replacement for turbos. Almost a third of the fuels energy is blown out the exhaust...
Forum:
03-24-2013, 10:20 PM
18
MOTOR Magazine 2013 Tyre Test
32,096
Posted By
d1ck
Why didn't they test any sticky tires?
Forum:
02-21-2013, 10:46 PM
23
Essex Harness Bar: Now Available!
10,011
Posted By
d1ck
Businesses operate to make money. Low volume...
Businesses operate to make money. Low volume products like this take plenty of time to develop and they have to make sure they get return on their investment in R&D. If you don't like the price,...
Forum:
Forced Induction
02-21-2013, 07:39 PM
190
UPDATE TRD Supercharger
107,169
Posted By
d1ck
I'm getting blue balls from hearing about this...
I'm getting blue balls from hearing about this and the innovate kit with no ETA for either...
Forum:
Forced Induction
02-13-2013, 09:27 PM
1,987
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ
676,720
Posted By
d1ck
This one accounts for the discrepancy between...
This one accounts for the discrepancy between their stock power numbers and the ones we're used to seeing. (Roughly 17.8%) This is based on their measured peak of 140 HP and what we normally see...
Forum:
Electronics | Audio | NAV | Infotainment
02-13-2013, 07:15 AM
9
Getting amplifier and subwoofer installed, what should I ask for?
2,341
Posted By
d1ck
I'm not sure how audio differs from other AC...
I'm not sure how audio differs from other AC circuits, but RMS is usually the peak power multiplied by .70711. I'm more of a mechanical guy, so I can't remember much about electrical theory.
Forum:
Forced Induction
02-12-2013, 08:29 PM
1,987
676,720
Posted By
d1ck
Seems legit.
Seems legit.
Forum:
02-11-2013, 11:26 AM
41
replace flywheel?
20,193
Posted By
d1ck
You seem to be completely against changing the...
You seem to be completely against changing the flywheel. Have you ever driven a vehicle with a lighter flywheel? It significantly improves engine response for both accelerating and decelerating with...
Forum:
Engine Swaps
02-07-2013, 05:34 PM
216
Has any FRS/BRZ fallen to LS V8 engine swap?
181,091
Posted By
d1ck
To everyone who says they hate it, or it's...
To everyone who says they hate it, or it's sacrilege: Please, grow up. The LS motors, are very small, light (Much lighter than any Toyota V8), and could most certainly be installed with minimal...
Forum:
02-03-2013, 08:56 PM
39
DIY Alignment
22,087
Posted By
d1ck
To the people who are suggesting to bring their...
To the people who are suggesting to bring their car to a shop, you are not the target market. This equipment is aimed towards people who fall into one of the following groups:
A) Like doing things...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
06:18 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
