follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 45
Search took
0.30
seconds.
Search:
Posts Made By:
keen as
Forum:
Forced Induction
05-19-2020, 06:40 AM
220
PROcede ESC User Software!
71,353
Posted By
keen as
Hi. This is the procede map I use. I tried to...
Hi. This is the procede map I use. I tried to have smooth, gradual ramp of boost in the low rpm, during hard throttle application and avoid bogging the motor. I have edited it to very slightly reduce...
Forum:
Forced Induction
08-31-2017, 01:19 AM
11,295
Full throttle Electric Supercharger Build Thread
3,413,415
Posted By
keen as
this is a copy of my PM reply. My problem...
My problem sounds different.
After I calibrated the throttle in the Procede Software, I didn't get full boost at full throttle. After a lot of time consuming...
Forum:
Forced Induction
06-26-2016, 03:28 AM
220
71,353
Posted By
keen as
That all makes sense. KoolBRZ I don't expect...
I don't expect any difference between 5.21v and 4.95V. After I get my dump pack back in, I'll log boost to see if there is any change when I switch from procede to...
Forum:
Forced Induction
06-25-2016, 11:51 PM
220
71,353
Posted By
keen as
NO, that post describes an an UNcalibrated...
NO, that post describes an an UNcalibrated throttle. In the zero rpm row, I populated the 80 and 85 column cells with "100". That was the only change in the map and I attached the picture showing...
Forum:
Forced Induction
06-25-2016, 03:59 AM
220
71,353
Posted By
keen as
KoolBRZ I had spare time to do some...
KoolBRZ
I had spare time to do some measurements.
I think they may be unreliable. Currently, my Dump pack is out of the car and the batteries are getting tested. While I am able to test the signal...
Forum:
Forced Induction
06-22-2016, 12:16 AM
220
71,353
Posted By
keen as
I tested both original (non throttle calibrated)...
I tested both original (non throttle calibrated) map and then calibrated map. The problem (described previously of less boost) only occurs after throttle calibration.
Forum:
Forced Induction
05-17-2016, 05:43 PM
75
TrackSpec Hood Louvers
45,352
Posted By
keen as
On a different, previous car I had, I covered the...
On a different, previous car I had, I covered the exposed air filter as a precaution. I didn't want to test for water reaching the air intake.
Otherwise, these vents look great and seem...
Forum:
Forced Induction
05-16-2016, 02:07 AM
75
45,352
Posted By
keen as
May I suggest, I think it is best to somehow...
May I suggest, I think it is best to somehow cover your air filter to prevent water getting onto it.
Forum:
Forced Induction
04-08-2016, 04:20 AM
255
Harrop 2015 TVS kit image..
106,036
Posted By
keen as
Big Thanks for data. Is the inlet...
Is the inlet manifold temps post intercooler?
Did the "inlet manifold" temps maintain stability until the end of the 13 lap stint? Were all 13 laps at full pace?
Forum:
Forced Induction
04-05-2016, 08:53 PM
255
106,036
Posted By
keen as
It would be great if you have any racetrack data...
It would be great if you have any racetrack data to share. Specifically, when heat soaked, what are your air intake temps? Did it effect engine management, eg timing and presumably power? Do the...
Forum:
Forced Induction
01-14-2016, 11:37 PM
11,295
3,413,415
Posted By
keen as
From website installation guide ...
http://www.phantomsuperchargers.com/uploads/1/2/4/9/12496102/frs-brz4a.pdf
Forum:
Forced Induction
01-06-2016, 04:39 PM
1,206
Phantom FTS Electric Supercharger Owners Thread
358,447
Posted By
keen as
Do what Gums said. The dump pack is separate and...
Do what Gums said. The dump pack is separate and does not get used or charged until the controller is on, when the car is on.
When my car is parked in my garage, I directly connect the starter...
Forum:
Forced Induction
12-29-2015, 08:32 PM
11,295
3,413,415
Posted By
keen as
If using Procede, you can delete the Drag...
If using Procede, you can delete the Drag reduction tube connected from the controller to air intake pipe. The hole can be plugged. I can't remember the size of the fitting to screw in to plug it.
Forum:
Forced Induction
10-17-2015, 07:44 AM
1,206
358,447
Posted By
keen as
Yes, I also found out that you can't copy a US...
Yes, I also found out that you can't copy a US ROM to Australian. There are probably undefined tables in the Australian ROM.
I am VERY DISAPPOINTED that Shiv and Openflash tablet are not...
Forum:
Software Tuning
10-09-2015, 08:03 AM
2
problem uploading tunes onto OFT
1,122
Posted By
keen as
that fixed it, Thanks.
Forum:
Forced Induction
09-22-2015, 06:00 AM
1,206
358,447
Posted By
keen as
Update ------ Rob suggested all the possible...
Update ------ Rob suggested all the possible reasons for my problem.
The problem was a connector at the electric motor.
The long story was I rechecked all connections, I reconditioned the...
Forum:
Forced Induction
09-16-2015, 06:12 PM
1,206
358,447
Posted By
keen as
Also the controller with upgraded cooling has a...
Also the controller with upgraded cooling has a foam type air filter between the cooling fan and controller case. I thought this may inhibit cooling airflow. Is it now standard?
Forum:
Engine, Exhaust, Transmission
09-16-2015, 01:39 AM
185
Mishimoto Build Thread: BRZ/FR-S Direct Fit Baffled Catch Can Kit!
92,423
Posted By
keen as
My car is NA. These pics are the inside of the...
My car is NA.
These pics are the inside of the stock intake tube.
I'm getting a catch can for the crankcase vent.
Forum:
Forced Induction
08-04-2015, 05:58 PM
11,295
3,413,415
Posted By
keen as
I bought a second hand unit. After one week, the...
I bought a second hand unit. After one week, the controller stopped working (no beeping after switching on/booting up). Rob is helping me resolve the issue.
Forum:
Forced Induction
07-22-2015, 11:17 PM
1,206
358,447
Posted By
keen as
I installed a second hand USA kit from Gary in...
I installed a second hand USA kit from Gary in NJ, and made longer cables to fit RHD in Australia. Thanks Gums for giving me the dump cable and to dtek for converting the USA tune for my A01G ROM.
Forum:
Forced Induction
05-08-2015, 04:07 AM
255
106,036
Posted By
keen as
https://www.facebook.com/harropperformance/photos/...
https://www.facebook.com/harropperformance/photos/a.161231640630974.42257.112028962217909/857663297654468/?type=1
Forum:
Forced Induction
03-26-2015, 09:25 PM
938
Edelbrock E-Force Supercharger
425,757
Posted By
keen as
Twincharged with Sprintex supercharger ...
http://www.ft86club.com/forums/showthread.php?t=74059&highlight=twincharged
Forum:
Software Tuning
03-11-2015, 06:45 PM
95
OpenFlash Tablet: Multiple Data Log files!
35,269
Posted By
keen as
Many thanks for a great update. And may I ask...
And may I ask again for option of temperature in Degrees Celcius?
Forum:
Forced Induction
12-04-2014, 11:54 PM
938
425,757
Posted By
keen as
from harrop facebook "2015 TVS Supercharger kit...
"2015 TVS Supercharger kit release sneak peak.."...
Forum:
09-03-2014, 08:54 PM
92
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
50,562
Posted By
keen as
see pic I borrowed in the preceeding post.
Forum:
09-03-2014, 08:53 PM
92
50,562
Posted By
keen as
I borrowed a pic from the NSW club
Forum:
08-31-2014, 02:16 AM
92
50,562
Posted By
keen as
i went to their facebook store. second from the...
i went to their facebook store. second from the top, listed at $450.
https://apps.facebook.com/aradium/?store=575575192519458
Forum:
Forced Induction
08-18-2014, 02:21 AM
11,295
3,413,415
Posted By
keen as
I understand you want to assess the fitment of a...
I understand you want to assess the fitment of a Nth American version for Aussie.
For the Aussie version, I discussed wire runs with Rob in January. I also provided measurements and pictures of...
Forum:
08-11-2014, 10:00 PM
81
Mishimoto Compact Baffled Oil Catch Can Build Thread!
47,036
Posted By
keen as
Thanks for showing development. What worked...
What worked better, the air/fluid entering the can on the bronze filter side or entering the side with the small silver diverter?
Thanks
Forum:
Forced Induction
08-06-2014, 10:21 PM
11,295
3,413,415
Posted By
keen as
Relevant article. About future Bugatti ...
http://www.drive.com.au/motor-news/new-bugatti-supercar-takes-shape-20140807-1019iy.html
"Further changes are also said to be in store for the induction...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
11:01 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
