follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 30 of 30
Search took
0.57
seconds.
Search:
Posts Made By:
Evan55
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
10-09-2020, 05:43 PM
401
Sticky:
How to screw up your cars handling and ride - step by step!
174,599
Posted By
ZDan
I called Bilstein and asked, the tech actually...
I called Bilstein and asked, the tech actually pulled up the drawings and said that the *only* difference between B6 and B8 struts for the FT86 is reduced bump travel in the B8s to prevent "loose"...
Forum:
10-08-2020, 11:44 AM
401
Sticky:
174,599
Posted By
bfrank1972
I have around -2.8 fronts with no problems with...
I have around -2.8 fronts with no problems with camber wear or driveability issues, at least once the tires warm up. I run about 34 PSI cold on MPSS, and starting out they tend be a little grabby on...
Forum:
10-08-2020, 10:05 AM
401
Sticky:
174,599
Posted By
Racecomp Engineering
Yeah as other's have said that's pretty close to...
Yeah as other's have said that's pretty close to where you need to be. A little bit more camber than that would help but that's still a good starting point.
There might a little bit of uneven wear...
Forum:
10-07-2020, 05:44 PM
401
Sticky:
174,599
Posted By
ZDan
I track my daily, I run -3.4 front and -2.8 rear...
I track my daily, I run -3.4 front and -2.8 rear camber, zero toe all around. Zero commute miles these days but I road-trip to tracks so a fair amount of street miles vs. track. Wearing pretty...
Forum:
10-07-2020, 03:33 PM
401
Sticky:
174,599
Posted By
NoHaveMSG
That is pretty close to my setup and I get the...
That is pretty close to my setup and I get the tiniest bit of camber wear. I am also DD'ing my car right now, street tires are wearing fine.
If you like rotation ditch the RS4's and go to...
Forum:
Tracking / Autocross / HPDE / Drifting
09-25-2020, 10:58 AM
44
Do not ignore VSC warning light at the track!
8,617
Posted By
ZDan
VSC warning light is a negative image of the "VSC off" light, see below for pic. When it comes on (at least in my case), the "VSC off" and "TRAC OFF" lights will go out. I also got the "ABS" light...
Forum:
08-23-2020, 07:36 PM
4
Seatbelt receptacle swap (passenger to driver)
1,113
Posted By
skylinekin
Update #2, driver seatbelt connector does not...
Update #2, driver seatbelt connector does not need to be attached, the car defaults to driver seatbelt connected so no warning light or chime!
So, I just cut the wiring off a spare passenger seat...
Forum:
07-22-2020, 10:54 PM
43
Helmets
5,209
Posted By
Yoshoobaroo
The reason race cars need HANS devices is the...
The reason race cars need HANS devices is the lack of airbags. A car with functioning airbags and seat belts with limiters will protect you better than a HANS device because your face is afforded...
Forum:
Member's Car Journals
02-10-2020, 03:41 PM
380
GSpeed's 2015 BRZ- SCCA Super Touring Build
126,004
Posted By
DaveGF
2020 race update
Motorsport Ranch SCCA January 2020: 2 races; 2 wins; new STU track record
Circuit of the Americas SCCA February 2020: 2 races; 2 wins; new STU track record.
Next up Hallett, OK, April 4 & 5.
Forum:
Mid-Atlantic
02-04-2020, 09:27 AM
4
SCCA HPDE/TT Events at Dominion Raceway
1,505
Posted By
J1Avs
SCCA Washington DC Region will be bringing HPDE and TT Events at Dominion Raceway this year!
Dates:
5/23-24 (86Cup Northeast Event)
6/27-28
9/26-27
Additionally, we will be hosting an...
Forum:
01-11-2020, 08:04 PM
380
126,004
Posted By
DaveGF
Update
2019 was a busy year for my BRZ and me in SCCA. Many ups and downs but that is racing. Highlight: Finished 2nd in the SCCA Hoosier Super Tour National points. Participated in my first SCCA Runoffs...
Forum:
BRZ First-Gen (2012+) -- General Topics
11-14-2019, 11:01 AM
95
17+ engine oil temps
17,288
Posted By
Tokay444
You guys should talk to some oil engineers. ...
260-270 is nothing on a modern synthetic.
Forum:
11-04-2019, 09:27 AM
95
17,288
Posted By
NoHaveMSG
You need to do a bit of research. There is so...
You need to do a bit of research. There is so much documented info here from people shearing their UOA's which would be the ultimate deciding factor. There was someone in the UOA thread that...
Forum:
11-03-2019, 08:50 PM
95
17,288
Posted By
ZDan
Quantify how "not good". Hydrodynamic wedge is...
Hydrodynamic wedge is a thing. Oil temps do get higher with sustained high rpm, but at the same time rpms provide film strength. 270F is not a problem for lubrication...
Forum:
11-01-2019, 06:53 PM
95
17,288
Posted By
ZDan
Ah, but we have data showing that the pressure...
Ah, but we have data showing that the pressure drop from running a cooler exactly negates the pressure benefit from having cooler oil!
Check it:...
Forum:
10-03-2019, 01:07 PM
278
SCCA T4 Build thread
57,772
Posted By
rice_classic
Some overdue updates
The FINAL ICSCC race was at the end of August and with everything going on I just haven't had a chance to update...
Totemo and were only a few points away in the championship in CT4 going into this...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
09-11-2019, 05:52 PM
367
Sticky:
Which wheels clear 17+ BRZ Performance Package Brembos
252,116
Posted By
pogofx
TSW Bathurst Gunmetal 17x8 35mm Offset ...
TSW Bathurst
Gunmetal
17x8
35mm Offset
Slightly Concave design.
Right at 40lbs mounted/balanced.
Flush fit with a little negative camber.
Wrapped here in Michelin PS4S's - 245/40/17.
Forum:
08-26-2019, 10:41 PM
420
Sticky:
Track Brake Pad Discussion Thread
228,721
Posted By
fminicooper
carid.com do not buy from ebay, they have...
carid.com
do not buy from ebay, they have the incorrect picture, shows xp735 but they deliver xp650
Forum:
08-21-2019, 03:14 PM
278
57,772
Posted By
rice_classic
Worthwhile update
If anyone was thinking about getting into racing - now is the time especially as we enter the off season where used race cars get really affordable. The T4 class in SCCA is very good and cost...
Forum:
07-30-2019, 08:39 AM
53
Wheel Directory: Enkei PF01 17x8.0 +45
44,223
Posted By
atomicalex
Plenty of clearance, at least as much as the OEM wheels from the spokes (actually probably about 3mm more to the face. The barrel is similar to OEM, maybe a hair more clearance.
I have the...
Forum:
07-25-2019, 10:10 PM
14
Two transmission issues
2,438
Posted By
Mr.ac
Well I'm not a fan of Motul, so naturally I would...
Well I'm not a fan of Motul, so naturally I would say it's due to the shitty tranny fluid. Lol
Have you tried changing tranny fluid?
As a Redline fan boy I would recommend Redline. Cause it's...
Forum:
FR-S / BRZ vs....
07-15-2019, 08:16 PM
109
Looking at a Miata after the FR-S
23,999
Posted By
strat61caster
What's a "car show"? ...
https://www.youtube.com/watch?v=R_tjM8eEqUo
Forum:
07-07-2019, 09:26 PM
367
Sticky:
252,116
Posted By
mixxxx
TRD forged 17x7.5+43 No spacers required ...
No spacers required
https://i.imgur.com/PLO8UsT.jpg
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
06-24-2019, 06:27 AM
29
The Mobil 1 oil rebate is back!
7,795
Posted By
RickyBobby
"Eligible oil products can be purchased together...
"Eligible oil products can be purchased together on one (1) receipt or purchased separately and, if submitted by mail, must be combined in one (1) envelope. Limit of four (4) rebates per household,...
Forum:
06-19-2019, 03:53 AM
119
FT86SF's Performance Package Brembo Info Thread
103,124
Posted By
timurrrr
I've created a new post to build a list of wheels...
I've created a new post to build a list of wheels that fit Brembos, and I intend to keep it up to date:
http://www.ft86club.com/forums/showthread.php?t=135328
Please post specs and photos of...
Forum:
06-19-2019, 03:30 AM
367
Sticky:
252,116
Posted By
timurrrr
Hi folks,
I have a '17 BRZ with PP, and recently started looking for aftermarket wheels.
To my disappointment, it turned out that those Brembos are so big that many wheels don't fit.
On top of...
Forum:
06-19-2019, 02:06 AM
40
Konig Ultraform - Flowformed lightweight wheels from a reputable brand!
23,665
Posted By
BRZ FAMILY FUN
They were the 17X8 ET40
Forum:
06-15-2019, 11:42 AM
100
Verus Engineering Brake Cooling Kit
44,103
Posted By
VerusEric
Thanks for the feedback! Awesome job on the...
Thanks for the feedback! Awesome job on the retrofitting for washer fluid!
Yes, each kit comes with 2013-2016 and 2017+ fog light mounting at this time. We revised the kits as of 2019 so...
Forum:
06-13-2019, 08:00 PM
1
AR-1, RR, RC-1 tire testing
2,835
Posted By
949 Racing
Testing was done on our Supermiata S1 racecar but we thought the 86verse might appreciate the insights. As covered below, weather conditions made it impossible to get repeatable and clean lap times....
Forum:
05-13-2019, 05:07 PM
278
57,772
Posted By
rice_classic
The 'hypersmooth' on the gopro was turned on so...
The 'hypersmooth' on the gopro was turned on so you get this weird pendulum effect from the camera. This cool thing is that the steadiness really shows how bumpy some of the track is as you can see...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:36 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
