follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 116
Search took
0.01
seconds.
Search:
Posts Made By:
Wepeel
Forum:
Tracking / Autocross / HPDE / Drifting
07-06-2017, 10:52 AM
32
Engine Cool-down Strategies for Autocross (Single Driver)
7,410
Posted By
Wepeel
If I'm single driving, I'll pull back into grid...
If I'm single driving, I'll pull back into grid and let it idle while I shutoff camera/data and reset tire pressures (usually a few minutes), then I'll shut off engine. I've found oil temps drop...
Forum:
Software Tuning
06-07-2016, 05:19 PM
57
High Negative LTFT on N/A BRZ causing idling issues
21,122
Posted By
Wepeel
Shiv told me that on the OFT the O2S2 and...
Shiv told me that on the OFT the O2S2 and Wideband AFR readings are not accurate - fwiw. O2S2 will always read 0.0v.
Forum:
Software Tuning
05-23-2016, 09:42 AM
34
Stuck in Open Loop?
10,980
Posted By
Wepeel
I just resolved my issue (posted in the datalog...
I just resolved my issue (posted in the datalog review thread).
http://www.ft86club.com/forums/showpost.php?p=2653838&postcount=1228
Turns out I needed a new rear O2 sensor. As part of my...
Forum:
Software Tuning
05-16-2016, 11:27 AM
2,150
Sticky:
Data Logs! Post them here.
503,733
Posted By
Wepeel
Alright I finally resolved the issue. The O2...
Alright I finally resolved the issue. The O2 sensor was threaded in fine. I replaced the O2 sensor and that fixed it.
So to summarize, during periods of extended cruise I was seeing AFR's drop...
Forum:
Software Tuning
04-25-2016, 10:16 AM
677
New Stage 2 UEL (91-93 and E85) OTS tune files
194,295
Posted By
Wepeel
Tested these tunes out, and for my car they seem...
Tested these tunes out, and for my car they seem a little too aggressive. I was getting up to -3.9 FLKC consistently at high load high rpm in 2nd gear autocross. On the previous tune I only ever...
Forum:
03-10-2016, 11:41 AM
3,914
Sticky:
STX Rules and Setup Questions
851,157
Posted By
Wepeel
This. Especially since the V3 comes with some...
This. Especially since the V3 comes with some very soft spring rates now, so you have to factor the price of a new pair of springs into the V3. 230/280 F/R I believe. Too soft for STX.
Forum:
10-26-2015, 04:05 PM
11
Braking Gs lower than Cornering Gs
3,080
Posted By
Wepeel
I just started logging autocross, but I get...
I just started logging autocross, but I get higher lateral G's than braking. Here's the gg plot. Typical STX trim (coilovers, camber plates, 245 RE71R 17x9, etc).
Forum:
Software Tuning
10-13-2015, 12:38 PM
29
OFT Stage 2 Tune comparable to stock 02-07 wrx?
9,205
Posted By
Wepeel
'02-'05 WRX were quite a bit less powerful since...
'02-'05 WRX were quite a bit less powerful since it has the 2.0 motor - the '06-07 had the 2.5. On paper it made about the same power but in reality the 2.5 is a lot faster than the 2.0.
Either...
Forum:
Software Tuning
10-04-2015, 12:26 AM
7
Where are LTFT data stored?
2,401
Posted By
Wepeel
I've wondered this and I think I've asked it...
I've wondered this and I think I've asked it before on here. The thing that throws me off is I've seen LTFT jump when MAF flow was the same but crossing RPM thresholds. On my previous car (STI) it...
Forum:
10-02-2015, 11:13 AM
22
External mic placement
6,615
Posted By
Wepeel
I place mine under the front driver seat. Does a...
I place mine under the front driver seat. Does a good job of getting rid of wind noise - depending on the mic too, some sort of windscreen might help too.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
09-24-2015, 03:04 PM
40
Whiteline front sway bar + endlinks
24,975
Posted By
Wepeel
It might not have been OP's issue, but any...
It might not have been OP's issue, but any KW-based coilover changes the distance from the endlink mount to the strut mount, so a shorter endlink is usually needed. In addition, the WL bar is shaped...
Forum:
09-24-2015, 11:33 AM
19
BC Coilovers - How stiff is stiff?
8,297
Posted By
Wepeel
For the lazy ...
For the lazy
http://www.ft86club.com/forums/showpost.php?p=1188723&postcount=107
Forum:
Engine, Exhaust, Transmission
09-14-2015, 11:17 AM
18
Nube question about catless header and emission
9,308
Posted By
Wepeel
It really depends on how your locality tests...
It really depends on how your locality tests emissions. A lot of the time, passing emissions is more about the tune than the hardware. In places that only check OBD codes/readiness, you can get...
Forum:
09-10-2015, 12:59 PM
61
Street Mod questions
15,736
Posted By
Wepeel
Yeah but that LS swapped 240 d1 car was slow......
Yeah but that LS swapped 240 d1 car was slow... 10 seconds behind an STX BRZ :)
The contour was actually in SMF, not SM.
There was a timing display at the finish, but you had to look toward the...
Forum:
08-26-2015, 05:16 PM
11
Open Flash Header Install Instructions/Video
5,628
Posted By
Wepeel
This is quite easy to do, and only need to get...
This is quite easy to do, and only need to get the front end up. Either jack stands or ramps.
Forum:
04-22-2015, 10:56 AM
52
Why a balanced setup is better than a "understeery" setup.
17,447
Posted By
Wepeel
Nice data, thank you. What is the rest of the...
Nice data, thank you. What is the rest of the setup like for the cars? Tires, bars, dampers, alignment/camber, absolute spring rates/stiffness, aero, ride height?
Forum:
04-17-2015, 12:33 PM
184
No front anti-sway bar=a better ride
47,695
Posted By
Wepeel
Isn't it more useful to look at spring and bar...
Isn't it more useful to look at spring and bar rates in terms of frequency?
Stock BRZ has a front wheel frequency in roll (spring+bar) of about 2.4Hz. Rear in roll is 1.92 Hz.
Stock FRS as a...
Forum:
AFRICA
04-09-2015, 09:22 AM
34
Random tip - cold starts
13,256
Posted By
Wepeel
Thanks guys. That makes sense. Nonetheless a...
Thanks guys. That makes sense. Nonetheless a good tip - maybe not a bad idea after an oil change.
Forum:
01-28-2015, 09:01 AM
21
KW Variant Spring Rates?
14,885
Posted By
Wepeel
The number is printed on the side of the spring -...
The number is printed on the side of the spring - KW prints the rate in N/mm and the length in mm. So the 343/400 were 170mm length and 60 N/mm in the front and 70 N/mm in the rear (60-170, 70-170)....
Forum:
11-05-2014, 11:33 AM
74
Near Stock v. OFT Stage 2 Dyno
55,220
Posted By
Wepeel
I believe the recommendation from Shiv is to let...
I believe the recommendation from Shiv is to let it idle for 60 seconds after a reflash without touching the throttle pedal.
Forum:
10-25-2014, 09:40 PM
672
Open Flash Header Discussion
200,035
Posted By
Wepeel
Put mine on last night, replacing a Borla UEL. ...
Put mine on last night, replacing a Borla UEL. Car seems to run smoother, and the OFH is quite a bit louder than the Borla on my setup - all stock except for header and Berk catted FP. OFH has a...
Forum:
10-23-2014, 11:08 PM
1
Coilover width data for wide wheel fitment
976
Posted By
Wepeel
If you get an OEM-style strut and run OEM style...
If you get an OEM-style strut and run OEM style springs the fitment will be just as limited as it is stock. (e.g. Bilstein B6 or B8 or Konis and an RCE or Swift Sport spring).
If you switch to a...
Forum:
10-19-2014, 07:28 PM
13
is there a shorter endlink out there? mcs motion control damper
4,569
Posted By
Wepeel
What I posted in another thread: ...
http://www.ft86club.com/forums/showthread.php?t=61472
Forum:
09-29-2014, 11:33 AM
12
Spring Length Question
3,563
Posted By
Wepeel
The longer spring will provide more travel before...
The longer spring will provide more travel before coil bind. May or may not be an issue depending on the setup. Also the 6" spring will be marginally heavier, if that makes a difference to you.
Forum:
Software Tuning
08-24-2014, 04:47 PM
36
OTS 2.05 Stage 2 UEL 91 Map - Need help to understand this log
8,743
Posted By
Wepeel
Mine is good too - Stage 2 93 2.0x. I'm within...
Mine is good too - Stage 2 93 2.0x. I'm within +/-3% most of the time, occasionally up to 3.9. Although, I do peg rich under WOT once I cross 5k rpm - can't figure that one out. Maybe I don't have...
Forum:
08-11-2014, 11:41 AM
31
What is the verdict on the Borla UEL?
11,095
Posted By
Wepeel
So the new one seems less noisy than the old one....
So the new one seems less noisy than the old one. I still hear some hissing/air noise under load but it's more in line with "aftermarket header noise" versus the "there's definitely a leak" noise I...
Forum:
Software Tuning
08-11-2014, 11:22 AM
1,062
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download
330,134
Posted By
Wepeel
Went from Stage 2 UEL 1.59 to Stage 2 UEL 2.0x,...
Went from Stage 2 UEL 1.59 to Stage 2 UEL 2.0x, highway cruise mpg seems similar. Will be able to verify daily driver mpg in a few days.
Forum:
08-06-2014, 11:19 AM
333
Sticky:
Developing a Proper Suspension Model
189,909
Posted By
Wepeel
Holy Crap! http://www.vsusp.com/
Holy Crap!
Forum:
08-06-2014, 09:44 AM
206
2014 SCCA Solo Nationals/Pro Solo Finale thread
43,626
Posted By
Wepeel
Registered, 23 STX, will be my first time out. ...
Registered, 23 STX, will be my first time out. 66 in STX! I wonder what the record is for biggest class.
Forum:
08-05-2014, 10:16 AM
32
The 2nd Official Shock Dyno Thread
18,613
Posted By
Wepeel
Keep in mind for the rear, since the MR is ~0.78,...
Keep in mind for the rear, since the MR is ~0.78, that the normal wheel speeds that are recommended for low speed / high speed (2 in/sec is the threshold in the first post) needs to be accounted for...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:26 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
