follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 5
1
2
3
4
5
Showing results 1 to 30 of 125
Search took
0.01
seconds.
Search:
Posts Made By:
Jdmjunkie
Forum:
Member's Car Journals
11-13-2023, 12:28 AM
173
Raven86Project's build thread
46,354
Posted By
Jdmjunkie
It looks great! Did you end up not doing the...
It looks great! Did you end up not doing the carbon e-brake cover?
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
07-19-2023, 08:12 PM
24,605
WHAT DID YOU DO TO YOUR FRS TODAY?
7,226,368
Posted By
Jdmjunkie
https://www.shapeways.com/product/D455RU5UN/scion-...
https://www.shapeways.com/product/D455RU5UN/scion-fr-s-extended-interior-fuse-cover?optionId=10371708&li=marketplace
Forum:
07-16-2023, 03:49 PM
24,605
7,226,368
Posted By
Jdmjunkie
https://www.shapeways.com/product/SXL23NA8X/ft86-d...
https://www.shapeways.com/product/SXL23NA8X/ft86-dash-mount?optionId=65523861&li=marketplace
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
06-12-2023, 02:27 PM
28
New Hood
16,650
Posted By
Jdmjunkie
I really want to order from them, I just can't...
I really want to order from them, I just can't justify the outlay of money for something that I won't get for a year.
It looks amazing on your car!
Forum:
Engine Swaps
06-05-2023, 09:46 PM
1,756
KPower Industries K24 swap
239,286
Posted By
Jdmjunkie
I don't understand why they would not already...
I don't understand why they would not already have the information on both stock flywheels. They already make clutch kits for both.
Forum:
Engine Swaps
06-02-2023, 06:30 PM
1,756
239,286
Posted By
Jdmjunkie
I have an adapter plate that hasn't been...
I have an adapter plate that hasn't been installed yet. In case you need anything measured.
Forum:
Engine Swaps
06-02-2023, 03:36 PM
1,756
239,286
Posted By
Jdmjunkie
I hope OS Giken responds positively. They make...
I hope OS Giken responds positively. They make some of the best clutches I have every used. And they only make noise when you push in the clutch because of the floating pressure plate. Also it would...
Forum:
05-16-2023, 06:01 PM
24,605
7,226,368
Posted By
Jdmjunkie
Nothing much. :bonk:
Forum:
05-16-2023, 05:29 PM
24,605
7,226,368
Posted By
Jdmjunkie
I installed my fire extinguisher mount today.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
05-12-2023, 08:03 PM
36
Help buying Suspension parts
2,701
Posted By
Jdmjunkie
I would recommend the Spl toe arms just for the...
I would recommend the Spl toe arms just for the reason that you can get the eccentric lock out so that the toe doesn't change after hitting curbs at the track.
Forum:
Issues | Warranty | Recalls / TSB
04-14-2023, 11:14 AM
4
What's this suspension part?
892
Posted By
Jdmjunkie
Swaybar endlink.
Swaybar endlink.
Forum:
04-09-2023, 12:13 PM
15
Lower but not make it stiffer?
1,903
Posted By
Jdmjunkie
Wisefab has a two inch drop knuckle setup, but it...
Wisefab has a two inch drop knuckle setup, but it is about $3k per axle.
Forum:
04-05-2023, 01:32 PM
264
Honda K24 Swapped 2015 BRZ Ship of Thesus (NASA TT5)
34,667
Posted By
Jdmjunkie
If you need it, I have a Kpower engine harness...
If you need it, I have a Kpower engine harness that you could use for the event if they don't get yours back in time.
Forum:
03-29-2023, 10:14 PM
10
2012 vs 2020 steering feel difference
1,648
Posted By
Jdmjunkie
Adding caster also increases steering weight.
Forum:
Engine, Exhaust, Transmission
03-24-2023, 08:03 PM
37
Battle Garage Ultimate Throwout Bearing
7,063
Posted By
Jdmjunkie
There is a 15 min video from CM Autohaus's...
There is a 15 min video from CM Autohaus's youtube channel linked on the shop page that show how much grease to apply inside the carrier. He said multiple times not to add too much or it will sling...
Forum:
03-24-2023, 03:36 PM
37
7,063
Posted By
Jdmjunkie
Just wanted to leave this here. I saw this the other day on CM Autohaus's youtube channel. It looks like a great upgrade. Thoughts?
Forum:
02-25-2023, 06:35 PM
114
Ace23_BRZ's DSport FA225 Boosted Build
36,615
Posted By
Jdmjunkie
I have wanted to do the courtesy lights for my...
I have wanted to do the courtesy lights for my car. You did a very good job.
Forum:
Forced Induction
01-30-2023, 07:09 PM
53
Best Clutch/Flywheel Brands (FI)
13,653
Posted By
Jdmjunkie
I like the clutch because it is light, easy to...
I like the clutch because it is light, easy to drive, and has a better throwout bearing. OSG clutchs are a complete system, so they include: flywheel and clutch, upgraded throwout bearing, and...
Forum:
Tracking / Autocross / HPDE / Drifting
01-03-2023, 06:07 PM
19
Slicks on 18" Wheels, Fender Package
1,877
Posted By
Jdmjunkie
Origin Lab makes a +25mm rear fender in the old...
Origin Lab makes a +25mm rear fender in the old style where it covers the whole quarter panel. That is what I want for my car. You could 3d print some small pieces for the rear bumper and c pillar to...
Forum:
11-15-2022, 11:09 AM
10
Aftermarket steering wheel choices..?
1,424
Posted By
Jdmjunkie
Are you looking for a wheel that reatains the...
Are you looking for a wheel that reatains the airbag? I have a J-Luth wheel that keeps the airbag and is 20mm deeper. It is a very high quality wheel.
Forum:
BRZ First-Gen (2012+) -- General Topics
11-07-2022, 09:06 PM
32
Need help figuring what parts to purchase
3,359
Posted By
Jdmjunkie
And then it will be slower than a stock car...
And then it will be slower than a stock car because it probably has a lower compression ratio for boost.
If you want good fuel efficiency in one of these cars buy a stock one, put on Verus under...
Forum:
11-07-2022, 08:09 PM
19
High Output Alternator
3,174
Posted By
Jdmjunkie
I have heard good thing about DC Power...
I have heard good thing about DC Power alternators. It would probably be worth the time to call them and see what they say.
Forum:
11-07-2022, 07:32 PM
32
3,359
Posted By
Jdmjunkie
The cc of an injector is how much it can flow at...
The cc of an injector is how much it can flow at 100%. The tuning software and tuner change the amount of fuel depending on load,rpm ,ect. Changing injector size only limits the maximum amount of...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
11-07-2022, 12:51 PM
6
What to do after putting in wrong transmission fluid
1,769
Posted By
Jdmjunkie
When my shop did my transmission fluid they...
When my shop did my transmission fluid they accidentally ordered all 300ls, so we called Motul and they said it wouldn't be an issue to run it.
Forum:
09-06-2022, 11:45 PM
18
Thoughts On Brake Booster Delete For My BRZ
3,108
Posted By
Jdmjunkie
I have been looking at the booster delete and...
I have been looking at the booster delete and chase bays say that you can retain abs. Just fyi incase you want abs for streetability.
Forum:
09-04-2022, 12:57 AM
48
Priming Oil System
7,294
Posted By
Jdmjunkie
If you hold the accelerator and clutch pedal down...
If you hold the accelerator and clutch pedal down it will crank the motor without starting. I do it after oil changes because you can't add oil to the filter before installing it.
Forum:
Transmission and Driveline
09-02-2022, 11:57 AM
4
Greddy Differential Cover
1,323
Posted By
Jdmjunkie
I bought this one, it isn't available. Sorry.
Forum:
08-13-2022, 05:08 PM
9
Denstoj Rocker Retainer Kit
1,600
Posted By
Jdmjunkie
I have a set unused if you are interested, I...
I have a set unused if you are interested, I bought them then decided to k-swap the car.
Forum:
Engine Swaps
08-08-2022, 11:52 PM
1,756
239,286
Posted By
Jdmjunkie
I wonder if Kpower will come up with a fix for...
I wonder if Kpower will come up with a fix for those of us who already have the harness. They need to make this right. I still can't believe that they didn't catch this on their test mule during R&D.
Forum:
07-03-2022, 11:01 PM
47
Jong's 2nd Gen BRZ
11,665
Posted By
Jdmjunkie
I love that interior sill in cabon. Does it look...
I love that interior sill in cabon. Does it look like it would fit a first gen?
Page 1 of 5
1
2
3
4
5
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
04:33 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
