follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 102
Search took
0.02
seconds.
Search:
Posts Made By:
celica73
Forum:
Issues | Warranty | Recalls / TSB
08-03-2015, 10:09 PM
5
P0351 and out of warranty
1,937
Posted By
celica73
Even if it is out of warranty it's just an $80...
Even if it is out of warranty it's just an $80 part and a 10 mm wrench to replace it.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
05-06-2015, 02:00 PM
184
No front anti-sway bar=a better ride
47,712
Posted By
celica73
As much as I want to LOL with you, that isn't the...
As much as I want to LOL with you, that isn't the case here.
965 311 B14 (rear) is a 14mm hollow bar. Stock is a 14mm solid bar. The hollow bar is softer.
Similarly, the front 965 311 A16 is a...
Forum:
Brakes, Suspension, Chassis
04-30-2015, 01:05 PM
35
PA:Back to stock
7,292
Posted By
celica73
how much is the mustang?
Forum:
04-22-2015, 03:12 PM
9
gt 86 rear sway bar
2,672
Posted By
celica73
I've given up on that, I just try to answer the...
I've given up on that, I just try to answer the questions now.
Forum:
04-22-2015, 01:05 PM
92
Stability Control very sensitive after coilovers installed
22,661
Posted By
celica73
What sway bars are on the car? What...
What coilovers did you install?
What is the ride height?
I wonder if you just don't have enough droop travel and the inside rear is unloading in every turn,...
Forum:
04-17-2015, 01:39 PM
184
47,712
Posted By
celica73
A helper spring serves a single purpose. Keep the...
A helper spring serves a single purpose. Keep the main spring from rattling around.
Maybe you were thinking of tender springs. Google that one, then come back and start posting more expert advice.
Forum:
Engine, Exhaust, Transmission
04-06-2015, 08:32 AM
13
What the hell came out of my trans/diff?
5,002
Posted By
celica73
What he said. Not something normally used...
What he said. Not something normally used internally, and not something normally used for parts that aren't supposed to come apart at a later date.
The last time I used a clip like that was for...
Forum:
Tracking / Autocross / HPDE / Drifting
02-21-2015, 09:53 AM
8
Looking to upgrade rear sway bar, any suggestions?
4,419
Posted By
celica73
Stock is 14mm. You can get rear bars from...
Stock is 14mm.
You can get rear bars from other Subaru's in most any size from 15mm (2010-2013 Outback) to 19mm (2008+ STI). I wouldn't pay more than $50 for one of the Subaru offerings....
Forum:
01-23-2015, 11:09 AM
7
CEL P0020 - "A" Camshaft Position Actuator...
6,709
Posted By
celica73
Oil starvation resulting in unwanted VVT changes?...
Oil starvation resulting in unwanted VVT changes? That's my best guess for a steady state sweeper. Does it happen with a stock tune?
Forum:
01-20-2015, 09:38 AM
21
Rear camber assymmetry and alignment issues
6,754
Posted By
celica73
Still not buying that argument. Shifting the rear...
Still not buying that argument. Shifting the rear subframe should* do very little to effect camber. ALL the suspension arms are connected to the subframe, shifting it left will just change the...
Forum:
01-01-2015, 08:52 PM
19
AutoX Launch Etiquette
6,320
Posted By
celica73
If there is room, then you launch the fastest way...
If there is room, then you launch the fastest way possible. In a game of hundredths, why give up tenths at the line?**
I don't pull up right behind the car at the line for a reason.
**The...
Forum:
09-22-2014, 07:53 PM
698
Sticky:
Track Videos - Directory and Discussion
204,984
Posted By
celica73
Pretty sure you used the wrong finger to wave at...
Pretty sure you used the wrong finger to wave at the NSX driver. The club I normally run with would probably black flag that guy.
Forum:
09-15-2014, 12:52 PM
46
Introducing the NEO Motorsport Big Brake Kit
17,723
Posted By
celica73
What is the D# for the pads? What happens to...
What happens to the pads at 1400 F (800 C)?
What do replacement pads cost?
Replacement rotor rings?
Is this for the front and rear? Does it retain the parking...
Forum:
08-30-2014, 09:20 PM
4
Fitment of open flash header
2,198
Posted By
celica73
What he said. Not even close to being an issue.
Forum:
08-15-2014, 02:14 PM
5
Eibach R1 Coilivers rusty/busted/cheap
1,961
Posted By
celica73
used car parts, buyer beware. Sucks but true. ...
Free bump.
Forum:
08-07-2014, 11:56 AM
222
How fast is the GT86 on track?
64,505
Posted By
celica73
troek gets it. A high horsepower car that...
troek gets it.
A high horsepower car that slows to 65 mph for a turn is somehow faster than the same high HP car that takes the turn at 70 mph. That never computes.
Anyone who uses that...
Forum:
07-15-2014, 08:26 PM
12
Battery Acid Problem
7,576
Posted By
celica73
The red is anti-corrosion spray, not battery...
The red is anti-corrosion spray, not battery acid. Unfortunately, in your case, it isn't working. I have the same red stuff on my car that is all stock, and it's been like that since brand new.
Forum:
06-16-2014, 09:36 AM
69
My car was wobbling at start up
14,554
Posted By
celica73
Where is the distributor on a BRZ? :popcorn: ...
It seems some folks have had issues with motor mounts being melted, all the exhaust heat is on the passenger side and so are the passenger side motor...
Forum:
06-13-2014, 10:13 AM
22
OFT/OFH with rest of exhaust stock...anyone?
10,980
Posted By
celica73
Not really. With the windows down there is a bit...
Not really. With the windows down there is a bit of growl when I first start the car moving. I've not really noticed that "boxer" rumble, even with a straight pipe.
Forum:
06-12-2014, 08:01 PM
22
10,980
Posted By
celica73
I've got it both (OFH, OFT) but there isn't much...
I've got it both (OFH, OFT) but there isn't much to hear. It's a little ratty at startup (the same complaint that everyone has with headers). After the initial cold start, you hardly know it's there....
Forum:
05-21-2014, 06:33 AM
20
HPDE instructors
3,385
Posted By
celica73
My last instructor was a neurosurgeon, I couldn't...
My last instructor was a neurosurgeon, I couldn't throw enough money his way for it to be noticed. Tell them thanks, offer to buy them lunch and keep the car on the track.
Forum:
05-16-2014, 02:30 PM
132
Fortune Auto Dreadnaught Pro Gen5 - anyone tried it on the track with feedbacks?
34,200
Posted By
celica73
Yeah, and I'd be happy to test a kit and make...
Yeah, and I'd be happy to test a kit and make comments too, if only they would give me something for nothing!
Forum:
05-15-2014, 07:25 AM
8
Lowering options with (near) stock rates and adjustable dampers?
2,246
Posted By
celica73
Lowered at stock or near stock spring rates will...
Lowered at stock or near stock spring rates will result in lots of time on the bumpstops, I don't think that is the droid you are looking for.
Forum:
05-14-2014, 10:00 AM
132
34,200
Posted By
celica73
Yall really ought to take this argument off-line....
Yall really ought to take this argument off-line. It's doing a disservice to both of you, and not really helping answer the original question.
Forum:
Engine, Exhaust, Bolt-Ons
05-13-2014, 01:58 PM
2,334
OpenFlash Header
346,121
Posted By
celica73
In many spots, there isn't enough room between...
In many spots, there isn't enough room between runners to wrap them individually.
As for reliability, yeah that was a joke.
It's also kind of loud with the nameless muffler delete. Really loud...
Forum:
DIY (Do-It-Yourself) Guides
04-30-2014, 05:01 PM
3
Tire rotation
3,002
Posted By
celica73
Are you planning front to rear or diagonal...
Are you planning front to rear or diagonal rotation? I put a 2 foot section of 2x4 on my floor jack, position it in the middle of the car on the seam (same seam where the jack points are) and lift...
Forum:
04-15-2014, 02:07 PM
28
Roll bar for FRS/BRZ
9,547
Posted By
celica73
I found a price on the site somewhere, it was...
I found a price on the site somewhere, it was around $1000. I do have some reservations about the bar.
It has extra bends on the main hoop, and they appear to be crush bends. It also doesn't have...
Forum:
04-13-2014, 10:59 AM
95
BRZ Battery died, when I tried starting it it made a terrible noise.
21,525
Posted By
celica73
at least the DI seal on the pictured injector is...
at least the DI seal on the pictured injector is in good shape! Ya have that going for you.
Sometimes things break, I'm not judging, could be one of many things. Glad they are fixing it for you!
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
04-12-2014, 09:03 PM
26
Wheel Directory: Motegi MR121 17x7.0 +48
14,961
Posted By
celica73
helicoil (if they make them that small), but...
helicoil (if they make them that small), but there might not be enough metal between the hub bore and the hole for a helicoil.
Forum:
04-07-2014, 09:52 AM
185
Functional Aero Parts and their effects ?
55,096
Posted By
celica73
I'll be honest, with a "mods" list and even more...
I'll be honest, with a "mods" list and even more mods listed to come, I don't get the vibe that you have much track experience. My apologies if you do, but if you do not, then the aero is the least...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
12:03 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
