follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 81
Search took
0.34
seconds.
Search:
Posts Made By:
DCStorm
Forum:
Audio/Visual, Electronics, Infotainment, NAV
09-28-2017, 10:51 AM
11
SOLD.
2,562
Posted By
ChrisGeezy
Is this Unit paired with an Android Device...
Is this Unit paired with an Android Device through BT or cable?
Forum:
Electronics | Audio | NAV | Infotainment
06-19-2017, 08:56 PM
29
Car not starting after head unit/speaker/amp install? HELP!
5,413
Posted By
Helios
Are the RCA plugs/ wiring for the speakers...
Are the RCA plugs/ wiring for the speakers shielded or unshielded? Are they run in close proximity to the power wire run from the battery to the amp? If the wiring is unshielded and run next to the...
Forum:
06-19-2017, 01:25 PM
29
5,413
Posted By
Packofcrows
Could be a bad ground/fuse. Ive had issues in...
Could be a bad ground/fuse. Ive had issues in different situations where i'm working with something installed thats new and it works fine a few times, then suddenly it doesnt and it turns out its a...
Forum:
06-19-2017, 09:31 AM
29
5,413
Posted By
Chimera
definitely have the shop correct the ground loop...
definitely have the shop correct the ground loop whine (aka alternator whine)
This can come from having the gain adjusted too high too, but it's their job to figure out if you paid for...
Forum:
06-19-2017, 08:59 AM
29
5,413
Posted By
22R
Again I said it is probably the battery it could...
Again I said it is probably the battery it could be something else but charge the battery first and check the voltage then go from there
Forum:
06-19-2017, 08:35 AM
29
5,413
Posted By
Doesn't mean it could not have been drained just...
Doesn't mean it could not have been drained just enough to not start the car. They were doing work that involves electrical after all.
If it happens again give it a check and actually rule it out....
Forum:
06-19-2017, 07:00 AM
29
5,413
Posted By
Bet you a beer it is the battery. It doesn't have...
Bet you a beer it is the battery. It doesn't have to click or try for the power to be too low to activate the starter but high enough to run everything else.
Wish I had a dollar for everybody that...
Forum:
06-19-2017, 06:29 AM
29
5,413
Posted By
guybo
This has nothing to do with the battery. If it...
This has nothing to do with the battery. If it was battery related, it'd try to start and fail. No noise, no click but power to the car means that something else is going on.
The shop that...
Forum:
06-19-2017, 02:20 AM
29
5,413
Posted By
Cal3000
It's most likely your battery. Your electronics...
It's most likely your battery. Your electronics can still work. Chances are you battery voltage is low and can't turn over the engine. Also, check the alternator. Make sure it's outputting around 14...
Forum:
06-19-2017, 12:16 AM
29
5,413
Posted By
Mr.ac
Sounds to me like it was the anti thief device...
Sounds to me like it was the anti thief device kicking in. A while ago another frs owner went through the same thing after getting an audio upgrade. If I recalled the trouble was with his key fob not...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
12-15-2015, 01:05 AM
31
Fix for loose sidemarkers?
12,311
Posted By
FRSBRZGT86FAN
There's no place to for a zip tie to actually...
There's no place to for a zip tie to actually attach to the sidemarker...
Forum:
12-14-2015, 11:23 PM
31
12,311
Posted By
lukey86
Mine were the same. I used some double sided tape...
Mine were the same. I used some double sided tape to hold them in place. Haven't had a problem since
Forum:
Exterior Parts (Aero, Lighting, Etc.)
06-25-2015, 03:14 PM
7
WTT: Trading my blacked out OEM headlights for your stock chrome headlights
1,966
Posted By
DAEMANO
Very fair deal. GLWS.
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
06-09-2015, 03:27 PM
20
Aftermarket Headlights
6,812
Posted By
FRSBRZGT86FAN
DCStorm I snapped some pics today after work so...
DCStorm I snapped some pics today after work so you have more of an incentive to get them I think the person above me has the chrome ones I however have the black ones because I think they fit...
Forum:
06-08-2015, 03:24 PM
20
6,812
Posted By
FRSBRZGT86FAN
Not really but they may look at such because the...
Not really but they may look at such because the cutoff is the same as OEM LEDs I've seen so at certain weird angles you may see a little light but where it matters you see a bright white beam
Forum:
06-03-2015, 09:14 PM
20
6,812
Posted By
ZOMFGAARON
My spyders cut off is great and the light output...
My spyders cut off is great and the light output looks normal for a projector headlight. Have pictures of it?
Forum:
06-03-2015, 09:01 PM
20
6,812
Posted By
The Feds
You could try retrofitting the stock headlights...
You could try retrofitting the stock headlights with something like this...
http://www.theretrofitsource.com/complete-retrofit-kits/morimoto-retro-quik-system-scion-frs-2012.html#.VW-h66NOnFo
Forum:
06-03-2015, 04:57 PM
20
6,812
Posted By
FRSBRZGT86FAN
Winjets are less of a hassle
Forum:
06-02-2015, 08:29 PM
20
6,812
Posted By
raven1231
I have the winjets. and have had zero issues with...
I have the winjets. and have had zero issues with them.
Forum:
06-02-2015, 08:23 PM
20
6,812
Posted By
FRSBRZGT86FAN
Have had the winjets for a couple days now...
Have had the winjets for a couple days now through severe rain, the lighting output is fine with the stock halogens if you aim them correctly which is imperative to have proper output. As for the...
Forum:
05-22-2015, 08:06 PM
90
Poll:
Do you find this picture Disturbing?
18,995
Posted By
Fishbed77
It's obvious that the car was parked there a...
It's obvious that the car was parked there a while back before the bush grew to its current size.
Forum:
05-14-2015, 02:25 PM
15
Monogram series headlights on a FRS
8,576
Posted By
NyC Zn6
No plug and play if I am not mistaken...must be...
No plug and play if I am not mistaken...must be wired independently and you have to do a resistor mod in order for DRL to work with headlights. You can purchase the DRL mod through Diode...
Forum:
05-14-2015, 02:24 PM
15
8,576
Posted By
mynameisnick4
The LED DRLs do not stay on with the low beams....
The LED DRLs do not stay on with the low beams. You have to mod the harness to do that. Diode Dynamics sells a plug and play harness to enable that functionality though (which I have one coming on...
Forum:
05-08-2015, 01:51 PM
8
Blacked out OEM headlights with HID kit
2,368
Posted By
SkAsphalt
If the reflector is black your DRL become much...
If the reflector is black your DRL become much much dimmer.
Forum:
Engine, Exhaust, Bolt-Ons
02-19-2015, 09:23 PM
14
FS: NEW BORLA CATBACK
3,101
Posted By
flat486
Will include blanket
Forum:
02-10-2015, 12:22 PM
222
2016 GT86 Toyota Press Release, 86 "style Cb"
81,919
Posted By
UtahSleeper
The front end does not match the rest of the car....
The front end does not match the rest of the car. Looks out of place and boring. Glad I have mine. The bumper and color is what sold me on the FR-S over the BRZ.
Forum:
12-09-2014, 12:36 PM
15
What the hell is that sound?
4,763
Posted By
Great now I have that picture as well! At least...
At least OP was good enough to provide a clip right from the start.
Nothing pisses me off more than the guys that post "I keep hearing a squeak in my car....
Forum:
12-09-2014, 03:48 AM
15
4,763
Posted By
NOHOME
The final words in the clip pretty much sum it...
The final words in the clip pretty much sum it up! NEVER heard that shit or else I would have been posting to ask the Manual Readers (Y'all are a small minority you know? ) What the HELL was that?
Forum:
09-06-2014, 07:58 PM
24,612
WHAT DID YOU DO TO YOUR FRS TODAY?
7,308,076
Posted By
JonAvalon
Installed Winjet Foglights, Rexspeed wide mirrors...
Installed Winjet Foglights, Rexspeed wide mirrors and enjoyed my victory Laffy Taffy thanks FT-86 SpeedFactory !! :happyanim:
Forum:
09-03-2014, 01:52 PM
11
FS: Valenti CR Taillights (Like New)
3,642
Posted By
FrSnake
Still available? price shipped to IL? and do...
Still available? price shipped to IL? and do these need a relay?? (If they aren't sold yet lol)
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
06:26 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
