follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 21 of 22
Search took
0.37
seconds.
Search:
Posts Made By:
BlOody_BoOger
Forum:
Forced Induction
12-07-2020, 08:45 PM
11,295
Full throttle Electric Supercharger Build Thread
3,448,759
Posted By
Target70
yeah, had corrosion all over one of my terminals...
yeah, had corrosion all over one of my terminals and covering one of my buss bars. I'm back and surprised how much more powerful it is. weak batteries really do ruin the experience. Also I ended up...
Forum:
Forced Induction
12-05-2020, 07:10 PM
18
Need Assistance, Car Not Making Boost!
2,487
Posted By
Kiske
Or the vac line under the intake popped off.
Forum:
Forced Induction
10-07-2020, 10:23 PM
11,295
3,448,759
Posted By
geraldjust
Hmm exactly that's what i would avoid. Im...
Hmm exactly that's what i would avoid. Im thinking of doing 3 nissan leaf batteries in series. This way i can get to 24v all full charge. and wiring a BMS to it with a charge it should not be too...
Forum:
Forced Induction
09-22-2020, 02:04 PM
11,295
3,448,759
Posted By
86TOYO2k17
BlOody_BoOger get a dragy and get some times.
Forum:
Forced Induction
08-16-2020, 09:29 AM
59
Forced induction temps?
9,474
Posted By
ML
You got me thinking so I made something to help...
You got me thinking so I made something to help with temps...I was able to get my temps down 10 degrees during my last track session with about the same ambient temps with this:...
Forum:
Forced Induction
08-10-2020, 10:36 AM
59
9,474
Posted By
ML
My JRSC setup hit 150F IAT at the track last...
My JRSC setup hit 150F IAT at the track last month in mid 90F summer heat.
Forum:
Forced Induction
08-10-2020, 08:59 AM
59
9,474
Posted By
86TOYO2k17
yeah i know yours is post blower so your getting...
yeah i know yours is post blower so your getting "true" IATs, but i still think they are possibly falsely high when under boost just because of close proximity to engine and the MAF "housing" is...
Forum:
Forced Induction
08-09-2020, 10:44 PM
59
9,474
Posted By
86TOYO2k17
Yeah you don’t need to. But it’s not real IAT...
Yeah you don’t need to. But it’s not real IAT temps.
OP trying to figure out what post FI boost temps are if he should intercool or not. As far as i know all PD blowers only measure pre FI/boost...
Forum:
Forced Induction
08-07-2020, 02:30 PM
11,295
3,448,759
Posted By
86TOYO2k17
BlOody_BoOger Oh yeah 120-140 is pretty normal...
BlOody_BoOger
Oh yeah 120-140 is pretty normal for IATs drawing air from inside engine bay, and engine temps heat soaking MAF being so close. I thought you meant IAT was 120 when WOT under boost....
Forum:
Forced Induction
08-07-2020, 12:11 PM
11,295
3,448,759
Posted By
86TOYO2k17
120 IAT really isn't super high, especially since...
120 IAT really isn't super high, especially since its summer in CA i am sure it's not that much higher than ambient. but it's not to say once stressing the system more that those temps wont go up way...
Forum:
Forced Induction
07-10-2020, 03:43 PM
11,295
3,448,759
Posted By
86TOYO2k17
are you referring to the hose going into the...
are you referring to the hose going into the intake pipe right before manifold? that comes from the crankcase breather on the engine?
You can plug that hole on the intake pipe, and vent the...
Forum:
Software Tuning
06-29-2020, 08:16 PM
11
Relocating MAF
1,613
Posted By
steve99
just be aware that the MAF sensor is also the...
just be aware that the MAF sensor is also the intake air temp sensor, so chaging it from pre to post turbo will not only likely chage its maf scaling but also the measured intake air temps will be...
Forum:
Forced Induction
03-03-2020, 10:58 AM
11,295
3,448,759
Posted By
86TOYO2k17
sprintex makes about 9psi on the 75mm pulley. ...
and yeah it will heatsoak with no intercooler after 1-2 10-15 second pulls.
but i think being belt driven from the engine adding more engine load,...
Forum:
Forced Induction
03-01-2020, 11:13 PM
11,295
3,448,759
Posted By
86TOYO2k17
Why not do it right with the proper wire/cable?...
Why not do it right with the proper wire/cable? Technically jumper cables would work but probably not ideal and may not be safe.
EWCS 1/0 Gauge Premium Extra Flexible Welding Cable 600 Volt Combo...
Forum:
Forced Induction
12-05-2019, 04:15 PM
11,295
3,448,759
Posted By
Lantanafrs2
They tried two torque amps together as well
Forum:
Forced Induction
11-14-2019, 12:09 PM
11,295
3,448,759
Posted By
WNDSRFR
Nope Why? The boost pressure decreases with...
Nope
Why?
The boost pressure decreases with rpm. Why would you want to have less boost?
Forum:
Engine, Exhaust, Bolt-Ons
07-22-2019, 11:32 PM
9
FS: Phantom Supercharger + Extras
2,884
Posted By
PantsDants
I do have the V1 switch still. PM me!
Forum:
Forced Induction
06-26-2019, 06:48 PM
1,206
Phantom FTS Electric Supercharger Owners Thread
361,578
Posted By
DAEMANO
Those are exactly my numbers on the dyno (hot...
Those are exactly my numbers on the dyno (hot day) with a very similar setup so.. confirmed and co-signed.
Forum:
12-17-2018, 12:19 PM
6
SOLD: Remove
2,230
Posted By
vfrqqq
I would be happy to only sell the compressor and...
I would be happy to only sell the compressor and the two-stage switch.
Forum:
Forced Induction
09-24-2018, 10:10 PM
11,295
3,448,759
Posted By
Gums
ESC will not be running all the time. Depending...
ESC will not be running all the time. Depending on your procede tune, engine load and throttle imput it may not come on at all in normal driving.
Procede, to me, just makes the BRZ feel like it...
Forum:
Forced Induction
04-26-2018, 10:54 PM
11,295
3,448,759
Posted By
Sojhinn
Very likely you will need a e-tune. I'd recommend...
Very likely you will need a e-tune. I'd recommend reaching out to shiv.
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:14 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
