follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 28 of 68
Search took
0.34
seconds.
Search:
Posts Made By:
GrandSport
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
08-20-2024, 05:43 PM
4
What is the Star/Torx Bolt on the bottom of the manual trans
324
Posted By
https://gt86stuff.onrender.com/t3Portal/document/r...
https://gt86stuff.onrender.com/t3Portal/document/rm/RM20S0U/xhtml/RM000002H8K00BX.html
Forum:
Tracking / Autocross / HPDE / Drifting
02-21-2024, 07:04 AM
117
Oil weight for track only car with a lot of cooling?
43,223
Posted By
autoracer86
You should see all the ways gas mileage...
You should see all the ways gas mileage calculation is done in Ireland/UK lol
Forum:
12-15-2023, 11:57 AM
117
43,223
Posted By
RT-BRZ
I know I should just shut up but this is really...
I know I should just shut up but this is really the whole point about tolerance/clearance.
Everything I've ever seen says that more narrow clearances in things like bearings generally necessitates...
Forum:
12-11-2023, 09:04 AM
117
43,223
Posted By
blsfrs
Nacl is a type of salt. There are others, if you...
Nacl is a type of salt. There are others, if you want to be specific.
- Sodium chloride.
- Potassium chloride.
- Calcium chloride.
- Sodium bisulfate.
- Copper sulfate.
- Magnesium sulfate...
Forum:
11-22-2023, 04:19 PM
117
43,223
Posted By
gnarjunkie
If your max oil temp is 235, then a 40w seems a...
If your max oil temp is 235, then a 40w seems a bit thick to me. Personally, I'd look at a viscosity chart and aim to have a similar viscosity at track temps as a street car would on 0w-20.
I had...
Forum:
11-21-2023, 08:26 AM
117
43,223
Posted By
Tokay444
I've run 40 year round, daily and track, in...
I've run 40 year round, daily and track, in Canadian winters, with 265,000 trouble free kms. If anything, for a track only car, I'd go up to 50 or 60.
Forum:
11-21-2023, 03:42 AM
117
43,223
Posted By
autoracer86
Looking into what is used in spec 86 series is a...
Looking into what is used in spec 86 series is a good place to start. I recall seeing 60W used over in Australia if I recall correctly
Forum:
11-21-2023, 12:57 AM
117
43,223
Posted By
cmiovino
If you're running 300v in 40 weight and it's...
If you're running 300v in 40 weight and it's working, why are you looking to change?
I see in your signature it's a full track car, caged, aero, etc... so you're probably ragging on it a good bit....
Forum:
11-03-2023, 11:38 PM
134
What's the best setup to learn
20,072
Posted By
gnarjunkie
What a weird group. Everywhere I've run...
What a weird group.
Everywhere I've run with or instructed with... if you have a small slide and catch it the correct response is "hell yeah nice work". Not "turn on the nannies".
Maybe if you...
Forum:
09-19-2023, 02:29 PM
28
NASA TT5/ST5 setup
7,911
Posted By
Kelse92
My old car with similar setup made 192 peak whp...
My old car with similar setup made 192 peak whp and a 181 average on a 93 tune.
https://drive.google.com/file/d/1LF_jRlmpxyDhP0zT6J5-9svujfFPvy7A/view...
Forum:
07-21-2023, 03:24 PM
46
Window ducts/air circulation
5,657
Posted By
CSG Mike
It wasn't as hot back then.
Forum:
07-21-2023, 02:01 PM
46
5,657
Posted By
Augh! You kids. Spoiled rotten.
Forum:
07-20-2023, 01:49 PM
46
5,657
Posted By
Careful! Vent location at the base of the rear...
Careful! Vent location at the base of the rear hatch was a major fail for the first year 240Z. I spent years sucking exhaust gasses whenever I didn't force fresh air into the cabin.
Forum:
07-19-2023, 07:35 PM
46
5,657
Posted By
soundman98
this gives me some pretty terrible idea's about...
this gives me some pretty terrible idea's about making an old-style window that can flip around in that area...
Forum:
07-05-2023, 10:07 AM
134
20,072
Posted By
ruturaj001
Thanks, that's very inexpensive, I would check...
Thanks, that's very inexpensive, I would check out if it's offered in nearby tracks.
Forum:
07-03-2023, 05:02 PM
134
20,072
Posted By
RhythmAddict0
I would just spend more time at the track. You...
I would just spend more time at the track. You probably don't need much in the way of modifications
Sent from my Pixel 7 using Tapatalk
Forum:
06-19-2023, 04:00 PM
146
Why did I wait so long to try the pedal dance
25,355
Posted By
RedReplicant
The two dips I called out were in a straight...
The two dips I called out were in a straight line. Eh, I will A-B them next event.
I'm running Haltech, rather than a stock BRZ ECU since kswap, but connect your Solo 2 DL to OBD or CAN...
Forum:
06-13-2023, 04:18 PM
48
Tracking with ABS fuse removed?
9,320
Posted By
RedReplicant
There are two forms of what some people call ice...
There are two forms of what some people call ice mode.
1. Lift a wheel on the brakes and ABS will shut off immediately, I haven't had this happen in the BRZ but I have in a Miata.
2. High, hard...
Forum:
06-13-2023, 02:10 PM
146
25,355
Posted By
ZDan
There are differences between what the '13-'16...
There are differences between what the '13-'16 and '17-'20 do in "track mode" and also with the "long-hold". '17-'20 is a lot less intrusive and I think only '17+ turns off E-diff with the...
Forum:
06-13-2023, 01:01 PM
705
Sticky:
Track Videos - Directory and Discussion
215,078
Posted By
Clipdat
Looks like a fun and challenging track!
Forum:
06-13-2023, 09:53 AM
48
9,320
Posted By
Racecomp Engineering
Yeah there are certainly better and worse ABS and...
Yeah there are certainly better and worse ABS and TCS and stability control systems. OR...adjustable TCS systems (i think the GR Cup cars, certain Lotus Elise/Exige models, lots of racecars, etc.)
Forum:
06-12-2023, 02:17 PM
146
25,355
Posted By
rice_classic
THIS. I raced a non-ABS car for 15 years...
THIS.
I raced a non-ABS car for 15 years before the FRS. When your tires are $350+ each, getting a braking moment wrong and writing off $700+ worth of rubber sucks.
Generally if you're...
Forum:
03-06-2023, 03:37 PM
6
Non-Coilovers options for track use
1,382
Posted By
Kelse92
I don't know a lot about ChampCar rules so is the...
I don't know a lot about ChampCar rules so is the ride height adjustability the problem? Spring changes? Both? Multiple line items?
Bilsten makes a pretty good OEM replacement shock you could...
Forum:
03-02-2023, 08:15 AM
54
Best track hood for cooling (coil overheating issue)
12,654
Posted By
M0nk3y
This is going to sound elementary. But when you...
This is going to sound elementary. But when you come off track are you popping the hood and letting the car vent and cool down?
Hood vents be dammed, when you're just sitting still air is stagnate...
Forum:
03-01-2023, 12:39 PM
54
12,654
Posted By
RedReplicant
I've got four of the Verus ones in my hood, I can...
I've got four of the Verus ones in my hood, I can see them pouring heat out on grid and they leave dust trails on the hood behind the vents after events
https://i.imgur.com/MQPDR9i.jpg
How...
Forum:
09-07-2022, 09:20 PM
31
Driving at the limit and slip angle
4,663
Posted By
CSG Mike
IMO, sell the Catalyst, and get a Solo 2 DL. ...
I don't think I'd call the GR86 underpowered. If you're not flat almost everywhere, it's definitely not underpowered, right?
Have you considered...
Forum:
09-07-2022, 07:55 PM
31
4,663
Posted By
CSG Mike
I want you to think about the bolded a bit more. ...
Coaching is too expensive, but you bought a catalyst?
Why is lap time of such importance to you? Do you want to "go fast" or "learn how to...
Forum:
Engine, Exhaust, Transmission
06-01-2022, 08:50 PM
15
Powertrain options for track only
1,745
Posted By
CSG Mike
I've found in my experience, that almost all...
I've found in my experience, that almost all clutch difficulties are install error, not the actual clutch.
Use a hardened steel clutch tool, or even a sawed off input shaft from any Subaru manual...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:25 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
