follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 481
Search took
0.71
seconds.
Search:
Posts Made By:
TommyW
Forum:
Engine, Exhaust, Transmission
01-05-2023, 08:06 AM
27
What’s the Best Oil for e85?
5,918
Posted By
KillerBMotorsport
Driven Racing Oils... The growing use of...
The growing use of Ethanol in modern pump fuel significantly increases the risk of carburetor and fuel system corrosion. Ethanol is added to fuel as an “oxygenate” for...
Forum:
Engine Swaps
12-21-2022, 03:08 PM
28
LS 3.6 4 cyl
3,589
Posted By
venturaII
Lol...no more torque dip..:lol:
Forum:
Tracking / Autocross / HPDE / Drifting
12-16-2022, 03:50 PM
29
Understeer on '22 BRZ
4,975
Posted By
glhs386
My theory is that you don't have enough roll...
My theory is that you don't have enough roll stiffness for the grip level of the tires which is causing you to ride down hard on the front bumpstops under cornering. This is where counterintuitive...
Forum:
12-14-2022, 10:32 AM
29
4,975
Posted By
Icecreamtruk
Sounds like a driver problem. Your setup isnt...
Sounds like a driver problem. Your setup isnt exactly the best (assuming you have stock springs since you didnt mention ratios) but you should be able to get the car to rotate more than enough with...
Forum:
12-04-2022, 01:09 PM
54
Best mods for corner speed?
7,610
Posted By
SCFD
This guy in the corvette had a bit of trouble...
This guy in the corvette had a bit of trouble shaking me: https://www.youtube.com/watch?v=cZRgrU3z4LM&t
Forum:
12-03-2022, 12:48 AM
54
7,610
Posted By
CSG Mike
What is optimal for me, will probably not be...
What is optimal for me, will probably not be optimal for you.
What is optimal for one track will probably not be optimal for another.
Rather than asking novice questions, why don't you ask...
Forum:
12-01-2022, 02:21 PM
54
7,610
Posted By
Desertnate
Those extra set of eyes and an impartial observer...
Those extra set of eyes and an impartial observer is very helpful.
I've had more experienced people ride with me on occasion either for fun (they want to see what my car is like) or at my...
Forum:
11-27-2022, 10:13 PM
54
7,610
Posted By
Pat
And the other 5% go faster with slower cars.
Forum:
11-27-2022, 09:18 PM
54
7,610
Posted By
CSG Mike
You're still asking essentially the same...
You're still asking essentially the same questions 3 years later. How much have you improved in those 3 years?
Isn't it interesting that the same questions illicit the same answers from me? ...
Forum:
11-20-2022, 03:07 PM
54
7,610
Posted By
CSG Mike
It depends on the level of modification. ...
It depends on the level of modification. Assuming you have minimal to no experience based on your question, your answer in order of most effective to least effective will be:
- Driver
- Tires
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
11-09-2022, 10:10 AM
44
Making the 86 more of a touring car?
6,695
Posted By
Sasquachulator
More than you can afford pal....Golddigger! ...
No one cares about the 17+ cars....
The 2013 cars are the REAL OG twins!, the TRUE twin driving experience, raw to the bone!
And that is most...
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
11-09-2022, 08:22 AM
18
Thoughts on ordering suspension from gr86 cup car?
4,143
Posted By
Racecomp Engineering
Unsure on the details, but just a completely...
Unsure on the details, but just a completely different system than factory.
- Andrew
Forum:
BRZ First-Gen (2012+) -- General Topics
10-30-2022, 10:49 AM
31
How many miles FA20 engines can survive with track use?
8,843
Posted By
Lantanafrs2
You'll get better answers on the troll thread
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
10-22-2022, 02:17 AM
21
Wider vs narrower tires
3,612
Posted By
soundman98
Stock used tires complement the characteristics...
Stock used tires complement the characteristics of the car very well. They also like to make noise near the limit faster than an ex wife if you even hint that the alimony check might be late.
Forum:
09-22-2022, 03:02 PM
69
oil pressure gauge
67,436
Posted By
DarkPira7e
You can view/log oil temp through any obd2 device...
You can view/log oil temp through any obd2 device that can read PIDs, but no pressure. I imagine bluetooth isn't really reliable enough yet to be piped through the firewall and be stable enough for...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
09-21-2022, 01:59 AM
21
Topping brake fluid
2,693
Posted By
Sapphireho
if your urine is orange, forget about your brakes...
if your urine is orange, forget about your brakes for a bit and go see your doctor asap.
Forum:
09-19-2022, 07:31 PM
47
Track events are getting out of hand 7 run groups at BW!!
5,885
Posted By
CSG Mike
Ultimately, if you want more seat time or less...
Ultimately, if you want more seat time or less groups, you gotta spend more money to get that time.
If you want less cars on track, then the cost per car goes up. You gotta spend more.
Forum:
09-18-2022, 12:17 PM
31
Driving at the limit and slip angle
4,331
Posted By
andyk5
How dare you call me Questionable!!!! :)
Forum:
09-17-2022, 01:27 PM
47
5,885
Posted By
strat61caster
It’s the fact that there are 7 run groups, they...
It’s the fact that there are 7 run groups, they can call them whatever, but dividing an 8 hour track day into 7 pieces means each group is going to get only slightly more then an hour of seat time,...
Forum:
09-12-2022, 02:17 PM
15
Front tire damage in skidpad.
1,721
Posted By
CSG Mike
Turn your steering wheel less, coming out of the...
Turn your steering wheel less, coming out of the turn.
You're causing your own push.
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
09-11-2022, 11:05 AM
3,774
Official Formula 1 thread
499,515
Posted By
The Red One
Nyck De Vries 1st F1 race has 2 points up on his...
Nyck De Vries 1st F1 race has 2 points up on his teamate…
Whatever ego Latifi had racing its just been crushed, add that he ran a clean race today makes it even worse.
The race was much finished...
Forum:
BRZ Second-Gen (2022+) -- General Topics
09-10-2022, 10:33 AM
4
Toyota Finally Turbocharges the GR86, NOT!
1,188
Posted By
3 And now the clickbait telephone game begins
3
Forum:
09-07-2022, 07:55 PM
31
4,331
Posted By
CSG Mike
I want you to think about the bolded a bit more. ...
Coaching is too expensive, but you bought a catalyst?
Why is lap time of such importance to you? Do you want to "go fast" or "learn how to...
Forum:
09-01-2022, 12:49 PM
24
Modify High Mileage 1st Gen or buy a new 2nd Gen
3,606
Posted By
foshjowler
I agree on adding boost to a car that didn't come...
I agree on adding boost to a car that didn't come with it from the factory, and tracking it. It's a can of worms I'm not sure most people want to get into. If you want a power car, then buy a power...
Forum:
08-30-2022, 11:10 AM
64
2022: Is there any risk to buy an 2013 FR-S now ?
6,916
Posted By
That is my point really. Two of the three...
That is my point really. Two of the three categories either wouldn't bother reading a Carfax or even if they did wouldn't care if the recall existed much less was done.
Ultimately it comes down...
Forum:
08-30-2022, 10:44 AM
64
6,916
Posted By
As I see it there could be three groups of...
As I see it there could be three groups of buyers:
1) People that hang out on social media and forums that know all about the recall fiasco and have a strong opinion on whether or not to have it...
Forum:
08-22-2022, 02:34 PM
64
6,916
Posted By
I bet that has taken out more of these cars than...
I bet that has taken out more of these cars than all the recalls, bad, tunes and other causes put together.
It is one of those "Oh I never did anything wrong" things though so other reasons get...
Forum:
Other Vehicles & General Automotive Discussions
08-20-2022, 10:21 AM
46
Going to sell my FRS and get something else
3,666
Posted By
bucketfoot
Not that it was a fast car, but I got out of a...
Not that it was a fast car, but I got out of a ticket years ago for pretty much this reason.
I got pulled over for speeding days after I had bought a Geo Storm. I told the officer that I had just...
Forum:
08-17-2022, 10:01 PM
46
3,666
Posted By
soundman98
last saturday, i was making my normal hardware...
last saturday, i was making my normal hardware store run.. leaving a light, i do what i normally do, rev out 1st. just as i'm shifting to 2nd with the motor screaming, i see a cop metering my lane...
Forum:
08-16-2022, 01:06 PM
46
3,666
Posted By
Oh I meant more if something is a really good...
Oh I meant more if something is a really good "deal". If you are getting what is normally an $80K car for $60K there is probably a reason for it.
A garage queen can be a good buy as long as it...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Site Announcements / Questions / Issues
12:54 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
