follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 58
Search took
5.16
seconds.
Search:
Posts Made By:
PikachuBRZ
Forum:
Northwest
05-25-2023, 12:50 PM
2
Track Alignment near Boise
637
Posted By
rice_classic
You can easily do an alignment yourself with a...
You can easily do an alignment yourself with a couple tools from Longacre (camber gauge, toe plates), a measuring tool/stick and a set of strings. Corner balancing is a different beast however.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-08-2023, 01:32 PM
4,440
Sticky:
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
1,153,606
Posted By
strat61caster
What’s wrong with the spc control arms? Also...
Also you can run e85 in ESP-LP, easier pax then XA even if you don’t buy Hoosiers.
17x9 +45’s rub in the front at full lock, I have a 5mm spacer on my...
Forum:
03-08-2023, 10:06 AM
4,440
Sticky:
1,153,606
Posted By
Racecomp Engineering
1. I prefer spherical bearings over poly in...
1. I prefer spherical bearings over poly in pretty much every scenario. Cusco work well since the bearing is protected from the elements with a rubber bootie, otherwise SPL are great. No experience...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
02-08-2023, 03:04 PM
16
Injector service, what else should I tackle?
3,018
Posted By
Capt Spaulding
Too often I use the alternative approach. Iffen...
Too often I use the alternative approach. Iffen bit ain’t broke I fix it til it is.
Forum:
Software Tuning
02-01-2023, 05:59 PM
2,150
Sticky:
Data Logs! Post them here.
511,164
Posted By
tomm.brz
npothing wrong to me, apart from a maf scaling...
npothing wrong to me, apart from a maf scaling not dialed in pretty good
i wouldn t mind that negative ltft during overrun when injectors are actually off
Forum:
Forced Induction
01-25-2023, 08:05 PM
6,011
Jackson Racing Supercharger Owners Thread
2,079,853
Posted By
CSG Mike
That would be a whole new tune, but re-tunes are...
That would be a whole new tune, but re-tunes are discounted.
https://www.counterspacegarage.com/ip-fa20-coilpack-set-ip-a149401-toyota-86-subaru-brz
Forum:
Forced Induction
01-25-2023, 07:21 PM
6,011
2,079,853
Posted By
CSG Mike
No issues with 1050X on a NA engine, but you'll...
No issues with 1050X on a NA engine, but you'll need a tune.
Zero burbles except perhaps on a high rpm WOT upshift.
Are you up to date on maintenance?
Forum:
Forced Induction
01-25-2023, 03:38 PM
6,011
2,079,853
Posted By
CSG Mike
The Ptuning FF kit will fit with the Rotrex...
The Ptuning FF kit will fit with the Rotrex reservoir.
You'll need a JR 4 BAR MAP and injectors for E85, along with the FF kit. I recommend ID1050X for their consistency and spray pattern.
Forum:
Forced Induction
01-25-2023, 02:29 PM
6,011
2,079,853
Posted By
JDMChris
Answers in Red.
Answers in Red.
Forum:
Forced Induction
01-25-2023, 07:51 AM
6,011
2,079,853
Posted By
Breadman
Replying inline in red
Forum:
Tracking / Autocross / HPDE / Drifting
12-10-2022, 11:56 AM
52
225/45/17 vs 245/40/17 Same Compound and Wheel, which is faster
12,334
Posted By
Tatsu333
I think he's laughing because the 40 and 45 refer...
I think he's laughing because the 40 and 45 refer to the aspect ratio of the tire - I.E. the height of the sidewall expressed as a percentage of the width, and you wrote (presumably just typo'd) it...
Forum:
11-25-2022, 05:19 PM
8
Help diagnosing weird left turns.
1,471
Posted By
norcalpb
Oh for some reason I thought you had CSG Flex...
Oh for some reason I thought you had CSG Flex A...yeah dude perfect time to upgrade lol.
Forum:
11-25-2022, 01:27 PM
8
1,471
Posted By
norcalpb
Yeah that’s some messed up movement at the pillow...
Yeah that’s some messed up movement at the pillow ball, but you could just rebuild the camber plates if you wanted.
Forum:
11-01-2022, 09:07 AM
4,440
Sticky:
1,153,606
Posted By
Breezio
Your on the right track, though your...
Your on the right track, though your understanding of SCCA Solo rules isn't quite right.
For the most part, mods put you in different class 'groups', like Street, Street Touring, Street Prepared,...
Forum:
10-26-2022, 03:37 PM
24
Track Setup
12,261
Posted By
NoHaveMSG
I get tons of contact on my fender liners.
Forum:
10-26-2022, 01:47 PM
24
Track Setup
12,261
Posted By
RedReplicant
I think most of us are in the same boat as deca...
I think most of us are in the same boat as deca there with the contact. I don't see full lock on track unless something has gone very wrong (or right) so I don't worry about it.
Forum:
10-26-2022, 11:29 AM
24
Track Setup
12,261
Posted By
deca
As others have said, look into camber plates....
As others have said, look into camber plates. Verus and Raceseng have nice options available. With lowering springs, plates and bolts I was able to run about 3.5 degrees in the front on 17x9 +35 with...
Forum:
10-25-2022, 11:13 PM
24
Track Setup
12,261
Posted By
SCFD
Rubbing or not largely depends on how you're...
Rubbing or not largely depends on how you're getting your camber. When using camber plates, the clearance between the wheel/tire and spring/strut remains the same. When using camber bolts to dial-in...
Forum:
10-18-2022, 10:52 AM
8
ISC Coilover Cover Length
888
Posted By
grumpysnapper
I use 300mm covers (but a different brand), and...
I use 300mm covers (but a different brand), and they are still a little generous in length.
Forum:
10-17-2022, 12:51 PM
4,440
Sticky:
1,153,606
Posted By
strat61caster
See: ...
See:
https://www.ft86club.com/forums/showthread.php?t=9936
Edit: you could have a stiffer spring rear but when you actually do the math it's still softer then the front effective stiffness, bump...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
10-17-2022, 09:31 AM
373
Sticky:
Which wheels clear 17+ BRZ Performance Package Brembos
260,454
Posted By
Breezio
You can't guess based on those numbers....
You can't guess based on those numbers. Especially with Enkei's.
17x8 +45 RPF1's clear PP brakes, 17x9 +35 do not clear.
I do not know the answer for the TS5's.
Forum:
10-13-2022, 01:58 PM
9
All of this work for a DIY alignment wasted
1,237
Posted By
DarkPira7e
I feel like I'm missing the point. What work was...
I feel like I'm missing the point. What work was wasted if you got what you wanted?
I agree with Alpha, needs red sidemarkers, please.
EDIT: It took me a couple re-reads- you didn't adjust...
Forum:
01-01-2022, 06:51 AM
4,440
Sticky:
1,153,606
Posted By
grumpysnapper
One thing that almost no one does, and I mean...
One thing that almost no one does, and I mean pretty much no one (myself included), is to start the whole process with yourself.
(I absolutely include myself in the following. And this is in no...
Forum:
12-02-2021, 11:51 AM
373
Sticky:
260,454
Posted By
sygfrid
Fo my winter set: Motegi Racing MR140 Size:...
Fo my winter set:
Motegi Racing MR140
PCD: 5x100
Offset: +45
Weight: 19.7 lbs
Plenty of brake clearance.
It can only fit small diameter lug nuts.
Forum:
Forced Induction
02-10-2021, 02:08 PM
6,011
2,079,853
Posted By
CSG Mike
Everything you know about *EJ* boxers doesn't...
Everything you know about *EJ* boxers doesn't apply to an FA.
Forum:
10-14-2020, 07:51 PM
4,440
Sticky:
1,153,606
Posted By
Captain Snooze
Yeah, I will take a down vote on my post. This is...
Yeah, I will take a down vote on my post. This is the price to be paid for not reading a thread in its entirety. To save you the trouble allow me to do this to myself. :slap:
Forum:
Forced Induction
01-25-2019, 04:58 PM
6,011
2,079,853
Posted By
JDMChris
Yes actually. On a 2017 BRZ Series Yellow. C38...
Yes actually. On a 2017 BRZ Series Yellow. C38 Kit with Track cooler.
http://i15.photobucket.com/albums/a374/jdmchris13/IMG_4794_zpsuqa3glzi.jpg~original
Forum:
Forced Induction
05-10-2018, 03:52 PM
6,011
2,079,853
Posted By
Anderzz
It's aliveeeee. Finally all set-up, tuned, etc. ...
https://i.imgur.com/5X4LsaN.jpg
Forum:
Software Tuning
04-01-2018, 01:10 AM
13
Understanding Fuel Trims
6,103
Posted By
tomm.brz
100 ron is between 91 and 93oct
Forum:
Software Tuning
03-31-2018, 08:31 PM
13
6,103
Posted By
Spuds
Large trims in one direction is likely to be due...
Large trims in one direction is likely to be due to incorrect maf or other sensor scaling.
Explanation: Under low loads, the engine runs in Closed Loop. This means that the maf sensor sees an...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:32 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
