follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 7
1
2
3
4
5
Last
Showing results 1 to 30 of 183
Search took
0.40
seconds.
Search:
Posts Made By:
J95
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-27-2024, 05:02 PM
42
Help me decide: KW V3 vs KW V3 Clubsport
5,768
Posted By
KiK
I have the following setup: Front: rebound 10...
Front: rebound 10 clicks from full stiff, bump 7 clicks from full stiff
Rear: rebound 9 clicks from full stiff, bump 8 clicks from full stiff
I have aprox. 40mm...
Forum:
03-25-2024, 09:52 AM
42
5,768
Posted By
Racecomp Engineering
You could do that but I would verify your...
You could do that but I would verify your installation first. I'll take a picture of where I'm at tomorrow with the same springs and OEM mounts (if I get over this cold).
Any coilover and...
Forum:
03-19-2024, 08:07 PM
42
5,768
Posted By
Our recommended settings won't really have any...
Our recommended settings won't really have any relevance to your KW V3s...they're valved differently and with different spring rates so I don't think I can give you anything to go on.
That...
Forum:
03-19-2024, 05:23 PM
42
5,768
Posted By
KiK
Got the car back from the shop and still...
Got the car back from the shop and still fiddling, to be honest, getting this dialed in has been a PITA! Also the ride is kind of harsh, highway was bumpy and city driving is just crashy, doesn't...
Forum:
03-12-2024, 12:57 PM
42
5,768
Posted By
That's an odd mix up from KW, but if he got the...
That's an odd mix up from KW, but if he got the measurements right then it's okay.
I'm using the exact same springs as you but with OEM top mounts and I'm about 25mm lower than OEM with room to go...
Forum:
03-11-2024, 11:55 AM
42
5,768
Posted By
Do you have a picture of the coilovers assembled...
Do you have a picture of the coilovers assembled with the camber plates but not on the car?
- Andrew
Forum:
03-10-2024, 12:09 PM
42
5,768
Posted By
It's probably the way he put the camber plates on...
It's probably the way he put the camber plates on the front. You should not use the purple cone piece if you're using the camber plates.
- Andrew
Forum:
03-09-2024, 09:34 PM
42
5,768
Posted By
Do you have a pic of the coilover assembly before...
Do you have a pic of the coilover assembly before it was installed on the car?
- Andrew
Forum:
03-09-2024, 11:55 AM
42
5,768
Posted By
KiK
Hi, the car is currently at the shop, once I get...
Hi, the car is currently at the shop, once I get the car back I will share the results with you. Should be ready within this week.
Forum:
01-23-2024, 08:35 PM
65
Front sway bar links with KW-based coilovers
12,377
Posted By
KiK
No, I'm curious to find if *YOU* need the...
No, I'm curious to find if *YOU* need the adjustable end links :laughabove:
Forum:
01-16-2024, 03:26 PM
65
12,377
Posted By
You will most likely be fine with the stock...
You will most likely be fine with the stock swaybar, endlinks, and 20mm drop.
With adjustable swaybars which have different mounting holes, it helps to have adjustable endlinks to make sure you...
Forum:
01-16-2024, 02:40 PM
65
12,377
Posted By
RedReplicant
When you're corner balancing it is somewhat...
When you're corner balancing it is somewhat unlikely that your corners will be the same weight side to side, so the shock bodies (and therefore sway bar mount tabs) will sit at different distances...
Forum:
01-16-2024, 02:33 PM
65
12,377
Posted By
KiK
Could you elaborate please? As you may remember...
As you may remember from the other thread, I will be running corner balanced V3s with a 20mm drop on stock sway bar and end links.
Is that an order for me to spend...
Forum:
01-15-2024, 02:11 PM
65
12,377
Posted By
NoHaveMSG
I guess we need to take different sway bars into...
I guess we need to take different sway bars into account. I have the Perrin adjustable on the softest mounting point. Moving the mounting point may have also caused an issue.
Forum:
01-05-2024, 03:01 AM
65
12,377
Posted By
Ruben_86_
You do not need to change them with kW v3 / cs
Forum:
12-24-2023, 11:32 AM
42
5,768
Posted By
I think you'll be plenty happy with the V3s with...
I think you'll be plenty happy with the V3s with the 5/6 springs for an all around fun set up. You could add swaybars later if you feel like you need it.
- Andrew
Forum:
12-24-2023, 05:06 AM
42
5,768
Posted By
marco_mc22
I can confirm, I’m currently on 50-250 front with...
I can confirm, I’m currently on 50-250 front with CS lowering mounts and minimum ride height is -32mm, using oem mounts would get the car sits higher, probably around -18mm as a max lowering.
Forum:
12-23-2023, 04:50 PM
42
5,768
Posted By
It doesn't matter too much to be honest, both...
It doesn't matter too much to be honest, both will work. The 170 is a tiny bit lighter. Especially in the rear, you have a lot of thread on the coilover and the longer spring won't limit the ride...
Forum:
12-23-2023, 12:05 AM
42
5,768
Posted By
KiK
Hay, I have the setup above sitting on the floor....
Hay, I have the setup above sitting on the floor. In January I will install it. Once I install it I can give you some feedback if you want.
I went with the Pedders top hats, they look and feel...
Forum:
12-22-2023, 12:17 PM
42
5,768
Posted By
Right different valving for V3 and CS. ...
50-200 front and 60-170 rear is exactly what I run on my car. It'll be good. :)
- Andrew
Forum:
12-21-2023, 02:28 PM
42
5,768
Posted By
Apologies, earlier I said 60-200 but 60-170 is a...
Apologies, earlier I said 60-200 but 60-170 is a better choice for the rear. I'm using 60-170 in rear with OEM top mounts
- Andrew
Forum:
12-20-2023, 12:41 AM
40
Whiteline Lower Control arms: What happened?
19,956
Posted By
norcalpb
I've had both WL and SPC and they both have "SPC"...
I've had both WL and SPC and they both have "SPC" stamped on them so they are indeed the same. This is also the case for the SuperPro arms.
Forum:
11-02-2023, 02:39 AM
42
5,768
Posted By
CSG Mike
Based on your stated use case, it is for comfort.
Forum:
11-01-2023, 01:26 PM
42
5,768
Posted By
OEM top mounts just improve comfort and will be...
OEM top mounts just improve comfort and will be quiet. The KW camber plates are pretty good in that regard, but nothing will be as good as OEM.
You could also use the Pedders top mounts that are...
Forum:
11-01-2023, 01:06 PM
42
5,768
Posted By
KiK
Thanks for the answers guys! What exactly is the...
Thanks for the answers guys! What exactly is the point of retaining OEM top mounts? Reliability? Noise? Wont it make the adjustment window more narrow?
Regarding the spring rate, so the plan is to...
Forum:
10-31-2023, 09:39 AM
42
5,768
Posted By
Ruben_86_
In Paris I had to stop and adjust the suspension...
In Paris I had to stop and adjust the suspension because it was terrible😅
Forum:
10-31-2023, 07:34 AM
42
5,768
Posted By
KiK
Hello, I am locked on the KW because they feature...
Hello, I am locked on the KW because they feature the required certification for the car to be road legal here.
I see that you are based in Spain,we are neighbors by a few hundred KMs.
How...
Forum:
09-22-2023, 03:42 PM
4,440
Sticky:
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
1,151,510
Posted By
autoracer86
Have a look at st suspension. It’s not as nice as...
Have a look at st suspension. It’s not as nice as the rce ss1/2 but you can get them in the eu and should be a pretty good setup on a budget. Otherwise open that wallet and go for broke lol
Forum:
09-22-2023, 10:15 AM
4,440
Sticky:
1,151,510
Posted By
autoracer86
I just got these a shipped a few weeks ago to...
I just got these a shipped a few weeks ago to Ireland https://shaftworksusa.com/collections/bilanx-competition-series/products/frs-brz-bilanx-competition-1-way-1
The shipping calcuator on CSG...
Forum:
09-19-2023, 02:31 PM
4,440
Sticky:
1,151,510
Posted By
IMO 1.2 inches is nothing to worry about. -...
- Andrew
Page 1 of 7
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
12:17 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
