follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 11
1
2
3
4
5
Last
Showing results 1 to 30 of 315
Search took
0.31
seconds.
Search:
Posts Made By:
ShadowReaper
Forum:
Software Tuning
02-15-2023, 12:48 PM
3
HRi tuning closed?
1,517
Posted By
Opie
Yes...he has. Would recommend Stew Jones at...
Yes...he has.
Would recommend Stew Jones at https://roguearttuning.com/
Or Zach at https://www.counterspacegarage.com/products/engine/ecu-programming-car-tuning
Forum:
Engine, Exhaust, Transmission
06-01-2022, 01:34 PM
12
Consensus on Delicious Tuning Coil Packs?
2,889
Posted By
I'll change plugs and packs when one starts to...
I'll change plugs and packs when one starts to misfire.
Forum:
Forced Induction
12-23-2021, 04:29 PM
23
Sticky:
To Everybody installing Forced Induction
56,127
Posted By
johnowow
ShadowReaper I’ve been boosted for almost 3 years...
ShadowReaper I’ve been boosted for almost 3 years now and have always avoided this process but you have explained it in the easiest way possible and I finally did it lmao, huge thank you!
Forum:
Forced Induction
03-26-2021, 05:59 PM
23
Sticky:
56,127
Posted By
Good luck! I know.... turbo takes up all that...
Good luck! I know.... turbo takes up all that working room :(
Forum:
DIY (Do-It-Yourself) Guides
12-10-2020, 02:17 PM
22
DIY: Spark Plug Change
9,307
Posted By
pope
Prove it’s doable. Extraordinary claims require...
Prove it’s doable. Extraordinary claims require extraordinary proof.
Set up and start a camera. Open the hood. Go through the entire process removing and reinstalling all four plugs. Close the...
Forum:
Issues | Warranty | Recalls / TSB
11-21-2020, 02:41 PM
29
ISSUE: 1900-2000 RPM Shutter/Shaking (Free load)
15,602
Posted By
"Stutter" That is the awkward thing about...
"Stutter"
That is the awkward thing about clutches. They may work fine under X conditions but not Y. Each can fail differently then another. It is where I would start at least since it could...
Forum:
11-20-2020, 09:04 PM
29
15,602
Posted By
Time for a new clutch.
Forum:
10-07-2020, 02:54 PM
12
Headlights Don't Turn on (Out at the Same Time)
2,566
Posted By
Will wake you up in a hurry!
Forum:
10-06-2020, 01:12 PM
12
2,566
Posted By
BigTuna
This is what I meant. Can you or have you...
This is what I meant. Can you or have you measured the voltage at the connectors when the headlights are in the on position?
Forum:
10-06-2020, 01:11 PM
12
2,566
Posted By
This ^ It has been seen here before. Just be...
This ^
It has been seen here before. Just be glad it didn't take the BCM out with them!
Forum:
FR-S / BRZ vs....
09-26-2020, 09:46 PM
52
To trade or nah
5,835
Posted By
Space...the final frontier.
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
08-31-2020, 06:16 PM
45
BRZ Headlight Black Out
34,258
Posted By
sharpsicle
Can confirm this. I've opened mine up 4 times...
Can confirm this. I've opened mine up 4 times now, and never needed new sealant. Never needed to pry them apart, just some oven mitts and a little patience.
All I do when I pull the halves apart...
Forum:
08-29-2020, 11:30 PM
45
34,258
Posted By
soundman98
the most common method involves using a flat...
the most common method involves using a flat blade screwdriver or a putty knife to pry the halves apart. if very little ends up on the screwdriver/putty knife, no. but if you end up with more...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
05-31-2020, 04:21 AM
264
Changing spark plugs
178,319
Posted By
airrick
i would wait. Only times you should consider it...
i would wait. Only times you should consider it unless youre at the interval would be if your car isn't starting up right away, misfiring, running weird, bad fuel economy, etc..
theres alot that...
Forum:
05-22-2020, 01:58 PM
264
178,319
Posted By
Ernest72
Did mine at 50k and they looked perfect. So you...
Did mine at 50k and they looked perfect. So you can wait for sure. I would only change early if getting a protune, but even that is overkill.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-16-2020, 02:18 PM
46
TRD Spring vs RCE Yellow Springs
31,228
Posted By
Tokay444
I didn't love TRD springs on oe dampers. Just...
Just switched to Sachs dampers and I do love them now.
Forum:
03-08-2020, 03:10 PM
46
31,228
Posted By
LancePower
I had TRD Springs on a 2016 FR-S. They ate up...
I had TRD Springs on a 2016 FR-S. They ate up several rear shocks within 30K miles. Not sure if it was spring rate or pot holes or improper installation or maybe a combination of all three.
I...
Forum:
01-31-2020, 10:12 PM
58
Best places for stickers
15,473
Posted By
and you're a dіck.
and you're a dіck.
Forum:
01-31-2020, 08:04 PM
58
15,473
Posted By
I flipped it upside down on him one time but he...
I flipped it upside down on him one time but he never said anything so somebody else probably fixed it before he noticed.
Forum:
12-24-2019, 09:40 AM
19
Dumb question on oil
3,731
Posted By
DarkPira7e
Are 20 and 0 the same number? Are 20 and 50 the...
Are 20 and 0 the same number? Are 20 and 50 the same number?
I would leave your car in the care of a shop to have your oil changed and ask their advice on the oil you should be using :)
Forum:
FR-S / BRZ vs....
12-16-2019, 07:09 PM
2,577
"Come Race Me Bro" Encounters
834,319
Posted By
dhuang
86/BRZ + No Brakes + Speed + Corner = Humbles...
86/BRZ + No Brakes + Speed + Corner = Humbles these folks quite well. :thumbup:
Forum:
Electronics | Audio | NAV | Infotainment
12-13-2019, 12:20 PM
5
Rexing Dash Cam (V1) Hard Wire Kit
2,739
Posted By
Stang70Fastback
Check out my blog post. I have some details on...
Check out my blog post. I have some details on how I hardwired mine to the fuse box. TL;DR, use the STOP light fuse for always on, one of the two P.POINT fuses for switched power, and use the bolt at...
Forum:
12-13-2019, 09:41 AM
5
2,739
Posted By
Impureclient
I used:...
I used: https://www.amazon.com/gp/product/B07G9WTWB9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Looks like yours has two wires for one on the always on fuse and another for the ignition...
Forum:
09-25-2019, 07:25 PM
42
Windshield Washer issue
13,557
Posted By
gravitylover
Pull the hose from the washer fluid reservoir and...
Pull the hose from the washer fluid reservoir and use some compressed air to blow the hose and nozzle out. A few short bursts shouldn't damage anything and is less likely to cause a leak than trying...
Forum:
FR-S / BRZ vs....
07-11-2019, 04:30 PM
2,577
834,319
Posted By
xdavidx
Can't believe you let those guys show you up like...
Can't believe you let those guys show you up like that... Clearly you were afraid to race them.
Seriously though, I had a guy in a crappy dark window tinted, fart box muffler, VW Jetta pull...
Forum:
06-20-2019, 03:24 AM
264
178,319
Posted By
Mr.ac
That's a long post. Service schedules are like...
That's a long post.
Service schedules are like wiping your ass.
You can use very little or not at all. You'll feel dirty and everyone around will smell your shity ass.
Or you can wipe till...
Forum:
12-18-2018, 08:38 PM
11
Needing help figuring out how to fix this gap in my bumper
10,294
Posted By
ajcarson11
Known problem -- Not a lot of great solutions....
Known problem -- Not a lot of great solutions. You can order OEM parts all day, but for most people replacement parts don't fix much. The bracket under the headlight tends to sag, and the bumper then...
Forum:
12-15-2018, 05:09 AM
49
Sticky:
FT86 Aftermarket Clutch Review
51,506
Posted By
Crystalwhitebrzsti
Clutch: exedy stage 2 15955 FI: Fullblown stage...
FI: Fullblown stage 1 with 2867
Mi: 20 LOL
Power?? Not sure never dyno (I assume same as other kits)
Lockout: nope
Stiffness: basically stock
DD: yup
Would I buy...
Forum:
12-03-2018, 09:28 PM
45
34,258
Posted By
Ivegotamain2
Here is my before/after. I ended up going...
I ended up going with 6-7 coats of the VHT engine enamel, sprayed in 10 minute coats and dried under a heating lamp. Let sit for 24 hrs.
https://i.imgur.com/0gcZcBi.jpg
Forum:
11-29-2018, 08:15 PM
10
Dash Cam install question
5,334
Posted By
NCtoBRZ
You're pretty lucky that using explosive devices...
You're pretty lucky that using explosive devices like mines inside of your car have caused no problems...
Page 1 of 11
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
02:47 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
