follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 9
1
2
3
4
5
Last
Showing results 1 to 30 of 270
Search took
0.01
seconds.
Search:
Posts Made By:
redlined600
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
06-02-2024, 03:39 PM
77
Brembo BM-4 caliper
23,518
Posted By
redlined600
That was my suspicion, thanks.
Forum:
Member's Car Journals
05-28-2024, 11:00 AM
172
Project rebirth, FRS - STX and trackday/TTD log
44,421
Posted By
redlined600
Quick update while I dig into the exhaust. ASM's...
Quick update while I dig into the exhaust. ASM's sale on the WF throttle body adapter was enough to push me over the edge. Yes it's a ridiculous amount of money for an adapter, but if it keeps me...
Forum:
05-21-2024, 11:55 AM
172
44,421
Posted By
redlined600
Got the car back out of storage so I can get back...
Got the car back out of storage so I can get back to work.
-ECU is mounted and hooked up.
-Fuel lines are done but I still need to pump out the old e85
-Really just picking at the little stuff...
Forum:
05-21-2024, 10:53 AM
313
ML's Whiteout
84,769
Posted By
redlined600
Holy crap! :-) Did you build that? What's...
Holy crap! :-)
Did you build that? What's you plan for the rear to balance? What are you going to do for suspension?
Forum:
Engine Swaps
03-13-2024, 01:42 PM
1,759
KPower Industries K24 swap
251,686
Posted By
redlined600
Nice, I made a similar brace (maybe I posted in...
Nice, I made a similar brace (maybe I posted in my build thread).
https://i.imgur.com/UXu8cIp.jpg
Forum:
Engine Swaps
03-12-2024, 10:43 AM
1,759
251,686
Posted By
redlined600
Maybe a bit of semi-useless info, but I was...
Maybe a bit of semi-useless info, but I was digging around a found that both the TSX and S2000 use manifold braces. This may be a moot subject if Kpower offers/switches to the balancer shaft setup. ...
Forum:
02-16-2024, 12:56 PM
271
Honda K24 Swapped 2015 BRZ Ship of Thesus (NASA TT5)
38,561
Posted By
redlined600
Following! I need that in my life. Nice work!
Forum:
02-05-2024, 04:20 PM
172
44,421
Posted By
redlined600
Went ahead and pulled the trigger on sphericals...
Went ahead and pulled the trigger on sphericals for the trailing arm. I chose these because they are rebuildable and use off the shelf bearings.
https://i.imgur.com/WmOu70F.jpg
Forum:
01-26-2024, 05:45 PM
172
44,421
Posted By
redlined600
I didn't want to sacrifice the the OEM ECU...
I didn't want to sacrifice the the OEM ECU housing so I printed one.
https://i.imgur.com/KwAYm0N.jpg
Also, thanks to RedReplicant for pointing these out! PCI sphericals for the FLCA. I'll slowly...
Forum:
DIY (Do-It-Yourself) Guides
01-25-2024, 11:24 AM
301
Official FT86Club 3D printing thread!
138,002
Posted By
redlined600
I only printed the gurney flap to add to the off...
I only printed the gurney flap to add to the off the shelf vent, but the end result is a bit similar. :D
It's split into 3 pieces, the outers hold down the center section....
Forum:
Engine Swaps
01-05-2024, 08:45 PM
1,759
251,686
Posted By
redlined600
I may have seen the same post on FB. I wonder if...
I may have seen the same post on FB. I wonder if compounding the issue of material selection is due the the linkage not being horizontal anymore, now it's putting vertical stresses into as well.
Forum:
12-11-2023, 05:16 PM
172
44,421
Posted By
redlined600
Added a couple goodies to the list for next year....
Stumbled across this set of Drag Cartel DICs locally. Should add a little spice!
https://i.imgur.com/ufaPJBz.jpg
Then, while browsing Ebay, I...
Forum:
Tracking / Autocross / HPDE / Drifting
12-01-2023, 10:47 AM
136
NASA ST4 - U build thread - engine swapped
18,590
Posted By
redlined600
Nice! I'd be curious to see what you end up with...
Nice! I'd be curious to see what you end up with for a TC strategy?
Forum:
11-21-2023, 02:01 PM
271
38,561
Posted By
redlined600
Good to hear! The smarty cam 3 sport is so...
Good to hear! The smarty cam 3 sport is so tempting for those reasons. I think I just need to pull the trigger at some point.
I thought there was an option in RS3 to select a static lap, I...
Forum:
Engine, Exhaust, Bolt-Ons
11-20-2023, 03:59 PM
3
FS: Setrab/mocal/aeroquip oil cooler
656
Posted By
redlined600
It's in the first picture
Forum:
11-11-2023, 02:55 PM
172
44,421
Posted By
redlined600
Radiator is back in and the plumbing is done....
Radiator is back in and the plumbing is done. Fuel pump relay, injectors and fuel rail are in. Lots of other little stuff completed.
The biggies left are modifying the S2000 header, pumping the...
Forum:
11-06-2023, 01:25 PM
172
44,421
Posted By
redlined600
I do sort of remember your thread, however at the...
I do sort of remember your thread, however at the time it didn’t apply to me so thanks for the reminder.
Here is what I actually know:
1. Multiple people have had vibration issues related to...
Forum:
11-03-2023, 01:30 PM
172
44,421
Posted By
redlined600
I put them in while the engine was out just in...
I put them in while the engine was out just in case. I'm planning on using the stock heat shields from the S2000 header as well (as much as I can).
I think you pointed the floor area out to me in...
Forum:
11-02-2023, 11:35 PM
172
44,421
Posted By
redlined600
I should have a few updates coming as things move...
I should have a few updates coming as things move along.
Engine is in!
https://i.imgur.com/f9KiuLx.jpg
Since I damaged the oem zip ties for the main harness I have been unsuccessful in finding...
Forum:
10-23-2023, 12:59 PM
271
38,561
Posted By
redlined600
Nice work! As they say, the best camera is...
Nice work!
As they say, the best camera is the one you'll use. I have a gopro but almost never look at the video because it's such a pain to sync to the data. That's truly the only selling point...
Forum:
Engine Swaps
10-16-2023, 10:56 PM
1,759
251,686
Posted By
redlined600
Cnc operator must have had a killer hangover that...
Cnc operator must have had a killer hangover that day. :bonk:
Forum:
Engine Swaps
10-16-2023, 03:09 PM
1,759
251,686
Posted By
redlined600
Oh fun, that's exactly what mine looks like. I...
Oh fun, that's exactly what mine looks like. I remember thinking it didn't seem to thread in very far when I installed it. Guess I'll give KPwr a call.
Edit: Kpower confirmed the same issue and is...
Forum:
10-14-2023, 11:34 AM
271
38,561
Posted By
redlined600
Its not all that surprising as the OEM selector...
Its not all that surprising as the OEM selector rod is pretty robust. I bet it sees some pretty substantial shock loads.
My original plan was to cut and weld the OEM one. I ended up buying the...
Forum:
10-13-2023, 10:18 AM
271
38,561
Posted By
redlined600
I'm not sure if they are happy or upset when you...
I'm not sure if they are happy or upset when you call, but they must know you on a first name basis by now though. :D
Forum:
Engine Swaps
10-09-2023, 12:02 PM
1,759
251,686
Posted By
redlined600
Is it the same place on the other side too. I may...
Is it the same place on the other side too. I may as well create some clearance while the engine is still out.
Forum:
10-08-2023, 08:01 PM
172
44,421
Posted By
redlined600
Small update before the engine goes in. ...
Tunnel modified, I decided to cut and weld rather than just bash it in.
grinder and paint......:lol: I've since cleaned and painted it....
Forum:
Engine Swaps
09-29-2023, 05:48 PM
1,759
251,686
Posted By
redlined600
I haven't seen a very good weight comparison of...
I haven't seen a very good weight comparison of the engines outside of a lot of speculation.
Couple of caveats:
-Header not installed on either engine. (FRS=~20lbs)
-The starter was installed...
Forum:
09-29-2023, 05:42 PM
172
44,421
Posted By
redlined600
Engine out. Don't mind the oil slick, I forgot to...
Engine out. Don't mind the oil slick, I forgot to drain the trans.
Lots of cleaning to do.
https://i.imgur.com/8C0jQ7O.jpg
Mating the trans the to K24 and one bolt didn't make it to...
Forum:
Engine Swaps
09-27-2023, 10:42 AM
1,759
251,686
Posted By
redlined600
Confirmed with Kpower it's a misprint. And...
And it turns out my flywheel is missing the alignment pins and pilot bearing. :iono:
*Edit, I guess it was missing the pilot bearing too. They sent out a...
Forum:
09-27-2023, 01:39 AM
271
38,561
Posted By
redlined600
Sucks about the motor! If you end up selling...
If you end up selling the DICs I might know someone that would be interested. :D
Page 1 of 9
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:22 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
