follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
0.49
seconds.
Search:
Posts Made By:
Racecomp Engineering
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
05-18-2024, 11:39 AM
287
MCA Suspension "Traction Mod"
90,943
Posted By
We really should reach out to MCA and see if we...
We really should reach out to MCA and see if we can carry these stateside considering how often I tell people to buy this thing lol.
- Andrew
Forum:
Site Announcements / Questions / Issues
05-16-2024, 10:54 AM
28
The death of ft86club
1,054
Posted By
It is extremely frustrating for us as vendors. ...
Essentially being cut off mid-conversation with people through PMs...it's unacceptable. Fortunately most know we're pretty available and easy to find...
Forum:
Member's Car Journals
05-13-2024, 08:59 PM
43
Doward's daily does it all: SCCA STX, NASA TT5, Gridlife ClubTR?
6,350
Posted By
I use the Deka ETX-30L on my daily, which sits...
I use the Deka ETX-30L on my daily, which sits for 3-5 days pretty frequently and outside during the winter. It's been great for a year so far. It's 20.2 lbs without posts.
I 3d printed the tray...
Forum:
04-25-2024, 11:21 AM
2
2nd gen GR86/BRZ struts on 1st gen?
383
Posted By
If you're swapping in complete 2nd gen assemblies...
If you're swapping in complete 2nd gen assemblies (dampers + springs + top mounts) then everything goes in nice and easy. The 2nd gen parts do ride better than a 2013 for sure. I would recommend...
Forum:
04-23-2024, 12:17 PM
4,440
Sticky:
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
1,148,446
Posted By
This forum is so damn clunky it's getting...
This forum is so damn clunky it's getting outrageous. Having so much trouble posting and and PMing lately.
Anyway, we have definitely seen our share of "uneven" Subarus in our time including from...
Forum:
04-05-2024, 12:15 PM
287
90,943
Posted By
Yeah that's the one. It's just the OEM arm with a...
Yeah that's the one. It's just the OEM arm with a nice sealed pillowball on the one end.
- Andrew
Forum:
04-05-2024, 11:15 AM
287
90,943
Posted By
I remember loosening but not removing those 2...
I remember loosening but not removing those 2 bolts as well, not sure why I needed to but I think I did have to for some reason.
Check japanparts.com
- Andrew
Forum:
04-05-2024, 10:10 AM
287
90,943
Posted By
I've made it a practice to order new bolts/nuts...
I've made it a practice to order new bolts/nuts for pretty much every install to just make life easier especially with crusty subframe pieces. Sometimes I even remember to use them!
For the...
Forum:
04-05-2024, 10:00 AM
159
Bilstein B6 and B8 explained
37,268
Posted By
No issues really, though with real downforce...
No issues really, though with real downforce you'd want stiffer springs.
- Andrew
Forum:
04-03-2024, 02:46 PM
287
90,943
Posted By
I have the MCA traction mod on my personal car,...
I have the MCA traction mod on my personal car, with a sort of custom 5k/6k KW/ST 3 way coilovers. I think it would be great with our RCE T2s. It's a good mod.
- Andrew
Forum:
03-25-2024, 09:58 AM
159
37,268
Posted By
I'd say about 5 kg/mm front and 6 kg/mm rear is...
I'd say about 5 kg/mm front and 6 kg/mm rear is as high as I would go.
- Andrew
Forum:
03-25-2024, 09:52 AM
42
Help me decide: KW V3 vs KW V3 Clubsport
5,482
Posted By
You could do that but I would verify your...
You could do that but I would verify your installation first. I'll take a picture of where I'm at tomorrow with the same springs and OEM mounts (if I get over this cold).
Any coilover and...
Forum:
03-19-2024, 08:07 PM
42
5,482
Posted By
Our recommended settings won't really have any...
Our recommended settings won't really have any relevance to your KW V3s...they're valved differently and with different spring rates so I don't think I can give you anything to go on.
That...
Forum:
03-12-2024, 12:57 PM
42
5,482
Posted By
That's an odd mix up from KW, but if he got the...
That's an odd mix up from KW, but if he got the measurements right then it's okay.
I'm using the exact same springs as you but with OEM top mounts and I'm about 25mm lower than OEM with room to go...
Forum:
03-12-2024, 12:49 PM
159
37,268
Posted By
Yeah it's certainly not just the bumpstops that...
Yeah it's certainly not just the bumpstops that make it feel that way!
FWIW I did not have a noticeable ride height change with my Bilstein B6. If there was one at all it was less than 5mm.
Forum:
03-11-2024, 04:50 PM
159
37,268
Posted By
Those won't fit inside the fronts, so the only...
Those won't fit inside the fronts, so the only real option is to trim the Bilstein bumpstops.
I wish there were another option but I searched a LOT and came up empty. Trimming the fronts isn't...
Forum:
03-11-2024, 11:55 AM
42
5,482
Posted By
Do you have a picture of the coilovers assembled...
Do you have a picture of the coilovers assembled with the camber plates but not on the car?
- Andrew
Forum:
03-10-2024, 12:09 PM
42
5,482
Posted By
It's probably the way he put the camber plates on...
It's probably the way he put the camber plates on the front. You should not use the purple cone piece if you're using the camber plates.
- Andrew
Forum:
03-09-2024, 09:34 PM
42
5,482
Posted By
Do you have a pic of the coilover assembly before...
Do you have a pic of the coilover assembly before it was installed on the car?
- Andrew
Forum:
Other Vehicles & General Automotive Discussions
03-06-2024, 11:26 AM
23
We made a podcast.
5,986
Posted By
We had Fez Babar on recently to talk about his...
We had Fez Babar on recently to talk about his experience in Gridlife Club TR class with his 2022 GR86 (the yellow one with the big wing). Good times. :)
Forum:
03-05-2024, 09:44 AM
192
spcmafia 18 BRZ
19,019
Posted By
You don't need dedicated auto-x pads and have to...
You don't need dedicated auto-x pads and have to deal with swapping before events. You can auto-x on your OEM pads if you want. Use em up if they still have meat or get something that feels good....
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
02-21-2024, 04:29 PM
1
OEM 16 Inch Wheels
621
Posted By
The suspension is the same for 16 inch wheel...
The suspension is the same for 16 inch wheel cars.
Since the OEM 16 inch wheels were never offered in North America, it's not likely to be easy or cheap to get them here. Not impossible but...
Forum:
BRZ Second-Gen (2022+) -- General Topics
02-16-2024, 11:34 AM
134
Tall People Solutions?
25,486
Posted By
Posted a write up here: ...
https://www.ft86club.com/forums/showthread.php?t=154465
Note this is for 1st gen...these seat rails do fit driver's side for 2nd gen and provide a 30mm drop (vs 40mm for...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
02-16-2024, 11:23 AM
14
Recaro SR7 + Kawai Works LOW seat rails
1,555
Posted By
I installed these seats + rails late last summer and have been enjoying them quite a bit.
https://cdn.recaro-automotive.com/fileadmin/user_upload/recaro-japan-sr7-gu-bk.png?v=1680083188
The...
Forum:
02-16-2024, 09:15 AM
23
We made a podcast.
5,986
Posted By
We recently had Jeff Perrin of Perrin Performance...
We recently had Jeff Perrin of Perrin Performance on our podcast to talk about their history, NASIOC, and his thoughts on the new 2022 "VB" WRX. There's a little bit of BRZ content too. And Mazda 323...
Forum:
Tracking / Autocross / HPDE / Drifting
01-31-2024, 10:15 AM
12
Podcast with Gresham Wagner (GR86 Cup racer)
1,325
Posted By
One of the rumors going around before about blown...
One of the rumors going around before about blown engines (though I'm not sure it's 100% confirmed) had to do with under-filling, which is somewhat common in spec series racing but a very bad idea on...
Forum:
01-31-2024, 09:56 AM
296
Spuds' Vroom Machine
25,806
Posted By
I've been thinking a lot about a better rear...
I've been thinking a lot about a better rear endlink solution lately. Nothing really to report, but yeah I don't love the poly endlink solution and OEM are too long. The WL endlinks are probably a...
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
01-31-2024, 09:26 AM
29
Early announcement for the 86BUTTDROP lowering brackets for OEM seats
7,166
Posted By
FWIW I have 40mm drop seat rails on my 1st gen...
FWIW I have 40mm drop seat rails on my 1st gen with Recaro SR7 seats (which I think also drop your butt a little) and the difference while driving is definitely awesome.
It is also definitely a...
Forum:
01-25-2024, 12:24 PM
12
1,325
Posted By
This was the 2023 schedule: March 30 to...
March 30 to April 2 – Sonoma Raceway (Sonoma, California)
May 5 to 7 – Circuit of the Americas (Austin, Texas)
June 16 to 18 – Virginia International Raceway (Alton,...
Forum:
01-24-2024, 12:40 PM
12
1,325
Posted By
Hey all,
We caught up with returning guest Gresham Wagner (2nd place finisher in the inaugural North American GR86 Cup series and previously 2022 SRO TCA champion in a 2nd gen BRZ) in our latest...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
01:02 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
