follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
0.04
seconds.
Search:
Posts Made By:
mrk1
Forum:
Engine, Exhaust, Transmission
12-05-2017, 08:19 PM
8
any DIY for 4.56 final drive install?
3,935
Posted By
mrk1
Possible with patience, the side shims are also...
Possible with patience, the side shims are also not included in any kit I know of. About $8 a piece.
This is the service manual for MK3 Supra, rear diff is the same. ...
Forum:
Engine Swaps
08-09-2017, 06:14 PM
20
What is everyone doing with their swapped cars diff.
11,265
Posted By
mrk1
Diff parts are interchangeable with the MK3...
Diff parts are interchangeable with the MK3 Supra. While there are some 200mm ring diffs in MK4's usually when someone refers to a MK4 diff its the big boy 220mm.
These diffs are pretty...
Forum:
Engine Swaps
08-02-2017, 01:13 PM
1,305
Another V8 Swap
325,417
Posted By
mrk1
TSS fab makes a tubular subframe with LS mounts
Forum:
Member's Car Journals
07-24-2017, 06:34 PM
783
A BRZ and a welder walk into a bar...
257,320
Posted By
mrk1
So much clutter, if it wont work no sense in...
So much clutter, if it wont work no sense in keeping it around.
Forum:
07-23-2017, 05:32 PM
783
257,320
Posted By
mrk1
New motor won't let me run a normal strut brace...
New motor won't let me run a normal strut brace so I came up with these WRC inspired supports.
http://i282.photobucket.com/albums/kk245/BmrBoy41/unnamed-5_2.jpg
Forum:
07-22-2017, 07:54 PM
783
257,320
Posted By
mrk1
With the motor in place its obvious the factory...
With the motor in place its obvious the factory clutch master wont work at all. I made the call to ditch the stock brake setup in favor of a manual non ABS setup.
Forum:
07-08-2017, 07:54 PM
783
257,320
Posted By
mrk1
Shaved a few inches and gained a mile ...
http://i282.photobucket.com/albums/kk245/BmrBoy41/unnamed-4_2.jpg
Forum:
07-04-2017, 01:52 PM
783
257,320
Posted By
mrk1
Pretty impressive these stock manifolds flow over...
Pretty impressive these stock manifolds flow over 300hp, still need to go.
http://i282.photobucket.com/albums/kk245/BmrBoy41/unnamed-3.jpg
The last test fit showed the pan still needed...
Forum:
Tracking / Autocross / HPDE / Drifting
07-04-2017, 09:22 AM
176
Track Builds Picture Thread
88,036
Posted By
mrk1
Kid on the way is slowing progress but it will...
Kid on the way is slowing progress but it will get there. HPDE/Hillclimber build.
http://i282.photobucket.com/albums/kk245/BmrBoy41/unnamed_2.jpg
Forum:
07-02-2017, 04:59 PM
783
257,320
Posted By
mrk1
Test fit the engine and trans, found more things...
Test fit the engine and trans, found more things that need to move but its progress.
Forum:
Engine Swaps
06-18-2017, 06:48 PM
423
GM LFX 3.6L V6 Motor Swap
185,830
Posted By
mrk1
Not very. I test fit mine with no oil pan, and...
Not very. I test fit mine with no oil pan, and clearing the firewall while keeping the front sway is a tight fit. There is no front sump option for the Ford so I've cut up a 3.5 FWD pan and will make...
Forum:
03-28-2017, 08:28 PM
39
IS300 M85/M98 rear diff - does it fit?
31,090
Posted By
mrk1
Right
Right
Forum:
03-27-2017, 08:33 PM
39
31,090
Posted By
mrk1
Sure you can buy new, 3.73 ring and pinion also...
Sure you can buy new, 3.73 ring and pinion also came in MK3 Supra.
Forum:
03-26-2017, 07:35 PM
783
257,320
Posted By
mrk1
http://i282.photobucket.com/albums/kk245/BmrBoy41/...
http://i282.photobucket.com/albums/kk245/BmrBoy41/unnamed-1_2.jpg
Finally getting back to some cage work. Trying out door bar designs, I like how this is looking.
Forum:
03-13-2017, 07:36 PM
5
PCV valve thread size
2,492
Posted By
mrk1
I drilled out the valve, pretty straight forward
Forum:
03-08-2017, 08:25 AM
783
257,320
Posted By
mrk1
I'm hoping to make a few more HP. By the time...
I'm hoping to make a few more HP. By the time it's running it will have headers, exhaust, intake and a tuned standalone. Maybe something more exciting then pump 93 if I feel up to it.
Forum:
03-05-2017, 02:22 PM
783
257,320
Posted By
mrk1
Rough test fit, hit where I expected, plenty of...
Rough test fit, hit where I expected, plenty of room where I wanted it.
http://i282.photobucket.com/albums/kk245/BmrBoy41/17141121_10154177101731010_655818920_n.jpg
Forum:
03-04-2017, 04:35 PM
783
257,320
Posted By
mrk1
FA20 is sold and ready to go. ...
http://i282.photobucket.com/albums/kk245/BmrBoy41/17140883_10154174954246010_2012932310_n.jpg
The new heart arrived quicker then expected, this is a Ford 3.7 V6...
Forum:
03-02-2017, 07:40 PM
78
Installed 3.91 rear diff from Lexus is300- amazing
32,192
Posted By
mrk1
So in a NA car going numerically higher then...
So in a NA car going numerically higher then stock (4.10) will result in quicker acceleration. Centrifugal SC can also benefit in this change since these SC need RPM.
In the example of this...
Forum:
03-01-2017, 07:04 AM
78
32,192
Posted By
mrk1
Only the guts of the MK3 supra can be swapped...
Only the guts of the MK3 supra can be swapped into a BRZ or IS300 case then mounted in the car. The MK3 case uses different style mounts.
Forum:
02-27-2017, 10:29 PM
78
32,192
Posted By
mrk1
3.73 is possible but harder to come across then...
3.73 is possible but harder to come across then the 3.91
Forum:
02-26-2017, 04:08 PM
783
257,320
Posted By
mrk1
http://i282.photobucket.com/albums/kk245/BmrBoy41/17028823_10154159395401010_1094250271_n.jpg
More liters maybe
Forum:
Forced Induction
02-21-2017, 06:41 AM
21
Possible for our FA20s to have the Torque Curve of the FA20DITs?
10,175
Posted By
mrk1
I ran a 28RS and loved it, peak torque was 4100...
I ran a 28RS and loved it, peak torque was 4100 if I remember right, that was also with a .86 hot side.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
02-15-2017, 08:53 PM
20
seam welding Chassis
4,292
Posted By
mrk1
Seam welding can go along with roll cage builds,...
Seam welding can go along with roll cage builds, car is stripped down and needs paint anyway.
Does it work, yes. Is it at all in anyway practical for a full interior street car, no.
Forum:
Engine Swaps
01-27-2017, 09:17 PM
1,305
Another V8 Swap
325,417
Posted By
mrk1
You can tilt it forward until it hits the back of...
You can tilt it forward until it hits the back of the headlights, its like 1.75" forward.
Forum:
Engine Swaps
12-28-2016, 08:21 PM
42
LQ4 V8 Swap
20,926
Posted By
mrk1
Swapping in the LQ will be hardly any different...
Swapping in the LQ will be hardly any different then an LS. The truck engines have bulkier intake manifolds and front pulley assemblies so those will need to be swapped over to one of the car...
Forum:
Engine Swaps
11-11-2016, 09:06 PM
1,305
Another V8 Swap
325,417
Posted By
mrk1
Our diff shares a casing with the IS300 and a...
Our diff shares a casing with the IS300 and a bunch of other Toyota/Lexus product over the years. The bearings are different yet the ring and pinion are interchangeable. MK3 Supra guts are also...
Forum:
11-09-2016, 09:10 PM
12
Spencer Fabrication T5 Trans Swap
4,807
Posted By
mrk1
Shifting at high rpms is a chore for syncros and...
Shifting at high rpms is a chore for syncros and most T5's are pretty old tech in this department. The T5Z has carbon syncros.
Forum:
11-09-2016, 09:04 PM
7
Stock catback with turbo
2,906
Posted By
mrk1
If your only running 8psi you will be just fine.
Forum:
Forced Induction
10-06-2016, 08:11 PM
16
Joining the Nitrous users club
5,757
Posted By
mrk1
Not really, collected a few more parts. I have...
Not really, collected a few more parts. I have been very busy so no time to get to the car. I will say I have taken more of a interest in drag racing so nitrous is more useful then ever.
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:12 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
