follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
0.05
seconds.
Search:
Posts Made By:
xwd
Forum:
Want-To-Buy Requests
01-18-2020, 09:20 PM
0
Looking for DGM/Asphalt front bumper
322
Posted By
xwd
My car is a 2013 and prefer one off a 2017+ but will take any year. I'm located in Atlanta and can drive a decent distance to pick one up.
Forum:
Engine, Exhaust, Transmission
07-22-2019, 11:45 AM
269
Racer X Intake manifold design, development, and results
61,465
Posted By
xwd
It came with the supercharger I'm using but you...
It came with the supercharger I'm using but you can find them on Ebay, I'll see if I can get the actual part number off it.
URD, urdusa.com makes the adapters. ...
Forum:
Tracking / Autocross / HPDE / Drifting
06-19-2019, 03:09 PM
299
Since beastronix is no more, what’s the alternative?
76,020
Posted By
xwd
For those that have an Ecutek setup, their latest...
For those that have an Ecutek setup, their latest version of the Ecutek connect software has a button to do the "pedal dance" as well. Not a super cheap option but figured if people had it already...
Forum:
03-25-2019, 09:59 PM
43
Scrothe Rallye 3 Harness - Pictures Installed
20,245
Posted By
xwd
For anyone who cares to look at the actual manual...
For anyone who cares to look at the actual manual these are the mounting instructions for the Rallye 3. They don't actually give a maximum belt angle but for those who think the mounting in this...
Forum:
Engine, Exhaust, Bolt-Ons
03-25-2019, 08:51 PM
9
TRD supercharger kit - GA
5,987
Posted By
xwd
I'm contemplating changing directions with the car and racing, so putting a feeler out for this supercharger plus everything else you need to install/run it. It's still not 100% PnP but pretty close....
Forum:
Forced Induction
12-16-2018, 09:14 PM
280
Sticky:
FI Dyno thread
245,146
Posted By
xwd
TRD SC update. Went from a 100mm pulley to 95mm,...
TRD SC update. Went from a 100mm pulley to 95mm, gained about 40hp and 30ft-lbs, peak was around 11.5psi. I have 90, 85, and 80mm pulleys left still. I think the highest run of the day was...
Forum:
Issues | Warranty | Recalls / TSB
11-08-2018, 03:13 PM
21
ABS C1288 - ECU Matching failed
13,556
Posted By
xwd
So if anyone runs into this in the future, there...
So if anyone runs into this in the future, there seems to be a bug in the Ecutek Racerom v10 code that causes this. After a long series of troubleshooting steps, upgrading to Racerom v11 fixed the...
Forum:
09-19-2018, 11:05 PM
19
2017 Complete Engine Partout
3,752
Posted By
xwd
Hey, this is Phil (dwx on NASIOC), you once...
Hey, this is Phil (dwx on NASIOC), you once picked me up the airport to pick up an old L in Tampa. :) In Atlanta now. Anyways, should have some tomorrow to make a list of what I need.
I definitely...
Forum:
09-01-2018, 02:39 PM
8
Custom Single Exit Exhaust thoughts
3,272
Posted By
xwd
Ah see you are in AU. I'm selling just the...
Ah see you are in AU. I'm selling just the muffler section off the UR exhaust, would make a good starting point for something custom since it's just v-band.
Forum:
09-01-2018, 02:38 PM
9
Crank pulley spacer removal; help.
3,746
Posted By
xwd
Having tried to actually remove the pin and drill...
Having tried to actually remove the pin and drill it out at one time, I can't imagine how hard of an impact hit it was to actually break it. And yes usually people have problems with that spacer...
Forum:
Forced Induction
07-10-2018, 11:10 PM
280
Sticky:
FI Dyno thread
245,146
Posted By
xwd
TRD supercharger 12.5:1 built motor, lots of...
TRD supercharger
12.5:1 built motor, lots of other stuff
~9psi. This is the largest pulley, I have 3 smaller ones.
Very conservative tune on E50, will tune more aggressively once there are...
Forum:
Forced Induction
04-29-2018, 02:14 PM
37
Another Catch Can Thread
10,921
Posted By
xwd
What he was getting at is the Harrop connects to...
What he was getting at is the Harrop connects to the stock PCV on the vacuum side of the supercharger (throttle body most likely), so there is no difference from stock and you don't need a check...
Forum:
12-16-2017, 04:51 PM
38
Differences between auto and manual engine
23,515
Posted By
xwd
Bumping this as I'm piecing an engine together...
Bumping this as I'm piecing an engine together now.
Does it really matter if the IDU matches the ECU? Is the IDU actually matched to a specific set of injector numbers? I have a complete engine...
Forum:
12-14-2017, 01:18 AM
28
Oil pan baffle plate
23,660
Posted By
xwd
Spoke to someone at Moroso. They did change the...
Spoke to someone at Moroso. They did change the design of the pan, almost two years ago now in Jan 2016. All of the product pictures they have out there are still the old pan... FYI, if you have an...
Forum:
09-05-2017, 11:46 AM
1,281
Spec Twin?
204,083
Posted By
xwd
Remains to be seen really. TR has a history of...
Remains to be seen really. TR has a history of doing exclusivity thing, but almost all of the parts are already available. The Konis are kind of the wildcard on whether those will be orderable...
Forum:
09-04-2017, 10:22 PM
1,281
Spec Twin?
204,083
Posted By
xwd
Theoretically a bone stock car goes into DS, and...
Theoretically a bone stock car goes into DS, and is allowed in SSC under the "underprepared" allowance. Just can't use alternate DS-allowed parts.
Forum:
07-29-2017, 04:58 PM
3,914
Sticky:
STX Rules and Setup Questions
860,299
Posted By
xwd
I sent a letter to Doug Gill last year about the...
I sent a letter to Doug Gill last year about the JR radiator/cooler combo and the answer was no it wouldn't be legal. Even if the dimensions were legal it's the "no other purpose" line for both of...
Forum:
Forced Induction
07-29-2017, 04:46 PM
1,372
Harrop TVS86 Owners Thread
395,994
Posted By
xwd
I'm hoping to make 425-450WHP on E85-R using the...
I'm hoping to make 425-450WHP on E85-R using the TRD S/C, which also has the TVS1320. It has a larger throttle body, snout, and plenum than the Edelbrock/Harrop kits so the airflow is probably a...
Forum:
07-10-2017, 11:50 PM
3,914
Sticky:
860,299
Posted By
xwd
Swaybars are kind of like 200TW ratings on tires,...
Swaybars are kind of like 200TW ratings on tires, they are all constructed differently so it's hard to gauge where they are against each other.
WL has a published stiffness on the 20mm bar of...
Forum:
01-19-2017, 05:27 PM
28
spec twins class in SCCA solo2
5,008
Posted By
xwd
A spec class has to use specific parts for...
A spec class has to use specific parts for suspension/power, no real room for interpretation. 17x8 wheels, tires open.
Forum:
12-21-2016, 09:14 PM
54
Custom trailer to carry 100 gal of E85 to track
12,294
Posted By
xwd
I just skimmed through this thread, but the...
I just skimmed through this thread, but the solution to your problem is a real trailer and tow vehicle.
Forum:
10-30-2016, 11:18 AM
4,833
SCCA Solo C Street Discussion
1,219,825
Posted By
xwd
The thought was you could run the taller 235/45...
The thought was you could run the taller 235/45 tires to add a little bit to the top end. One of the better autocross runs I've seen on video is Ogburn's from 2015 nationals where his fast run on...
Forum:
09-20-2016, 03:41 PM
4,833
1,219,825
Posted By
xwd
There is no backdate in Street, you could only...
There is no backdate in Street, you could only run them on a 2017.
Forum:
09-15-2016, 01:59 PM
3,914
Sticky:
860,299
Posted By
xwd
Based on stock tire size I think the theoretical...
Based on stock tire size I think the theoretical is 57. If you have a 7800 RPM redline the 4.1 results in a 62mph redline, with the new 4.3 gearing it's 59. If you rev to 8000 it's 61.
Forum:
09-10-2016, 07:21 PM
3,914
Sticky:
860,299
Posted By
xwd
It wasn't less friendly to cars with power. It...
It wasn't less friendly to cars with power. It had a really tight right hander right before a place where you could open it up. He just drove better than everyone else in a well prepped car.
Forum:
09-10-2016, 06:48 PM
123
Tire Trailers
50,055
Posted By
xwd
Yeah I used Rustoleum too and it's not great. I...
Yeah I used Rustoleum too and it's not great. I figured for the price I wouldn't put too much into it. One of those things where it looks good from about 20 ft. away. :)
If I ever have to...
Forum:
09-09-2016, 09:51 PM
94
2016 Solo National Championship roll call - who's going?
18,033
Posted By
xwd
Hey Mike you should definitely toot your own horn...
Hey Mike you should definitely toot your own horn a bit, coming in 4th in that group of guys is awesome, many national champs in there.
I didn't drive great and also left the TC on my first West...
Forum:
08-28-2016, 04:08 PM
94
18,033
Posted By
xwd
I'll be arriving Sunday, doing some T&T runs on...
I'll be arriving Sunday, doing some T&T runs on Monday. I just signed up for the EVO one, seemed like the best deal. If I get there early enough will try to do some on Sunday as well.
#55 STX,...
Forum:
Forced Induction
07-28-2016, 10:51 AM
80
HELP! Jackson SC vs. Harrop SC
18,852
Posted By
xwd
When I priced out the Harrop it wasn't that...
When I priced out the Harrop it wasn't that expensive and shipping wasn't that much. There are a couple people in the US like Moto-East and CSG who I think can supply kits now as well. Install is...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
07-28-2016, 08:57 AM
53
Moton clubsport suspension
12,883
Posted By
xwd
For US autocross a lot of people are using even...
For US autocross a lot of people are using even spring rates or slightly stiffer in the rear. 7k/7k or 7k/8k, depends on sway bars or just personal feel. I think your rates for track use at 9k/11k...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
05:48 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
