Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Garage
Branka
Tristor's Avatar
Tristor Tristor is offline
Vehicle Name Branka
Year 2017
Make Subaru
Model BRZ
Color Crystal White Pearl
Packages Limited
History Purchased in December 2017 as a Christmas gift to myself.
See build thread here: https://www.ft86club.com/forums/showthread.php?t=125493
Exterior
Perrin Rear Wing Risers
Verus Engineering Carbon Fiber Side Marker
Trackspec T1 Hood Louvers
STI JDM Fog Light Bezels w/o Fog Light Holes
Interior
Shrader Performance Rear Seat Delete Kit
"Branka" Carbon Fiber Center Console Plaque
TRD Door Stabilizers
AIM Solo 2 DL w/ Mount
Under the Hood
K&N air filter
Samco Inlet Tube + Sound Generator Delete
Jackson Racing Dual Radiator and Oil Cooler
CSF Aluminum Radiator Filler Neck
Samco Radiator Hoses
APR Carbon Fiber Cooling Plate
Stark Performance Automatic Transmission Cooler
PTuning Windshield Washer Reservoir
PTuning Lightweight Battery Tray
Shorai LFX36L3-BS12 4.8lb battery
Grimmspeed Pulley Covers w/ Tool Tray
Fumoto Quick Engine Oil Drain Valve
AMSOil Signature Series 5W-30 motor oil
AMSOil Signature Series coolant
Redline D6 ATF
Castrol SRF Brake Fluid
Suspension
CSG Spec Brembo GT (BM4) in front, OEM brakes in rear
CSG C2 (Front) and C1 (Rear) brake pads
Spiegler stainless steel brake lines
Cusco Front Strut Bar w/ Master Cylinder Brace
Cusco Rear Strut Bar
Whiteline KCA434 and W0509 Front LCA Bushings (+0.5 degree caster)
Whiteline KSR210 Steering Rack Bushings
Whiteline KDT925 Differential Cradle Bushing Inserts
Whiteline W63414 Trailing Arm Bushings
Whiteline KDT922 Rear Subframe Bushing Inserts
SPL Parts Rear LCA
SPL Parts Rear Toe Arms w/ Eccentric Lockout
RCE Tarmac 2 coilovers w/ 400/400 springs
Vorshlag High Caster Camber Plates (Front)
Vorshlag Spherical Shock Mounts (Rear)
STI JDM Engine Mounts
STI JDM Transmission Mount
Torque Solutions Driveshaft Center Bearing Solid Bushings
Wheels and Tires
ARP Extended (3") wheel studs all around
Motorsport Tech wheel spacers (various sizes depending on alignment specs)
Rays Volk Racing ZE40 Time Attack Edition (18x8.5ET44)
Yokohama Advan Neova AD08R 225/40R18
APEX ARC-8 FT86 Wheels in Anthracite/Gunmetal (17x9ET42)
Hankook Ventus RS4 245/40R17
CSG Spec Racing Lug Nuts
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
